Rear shock R/R
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LVTacoma, Jun 4, 2010.
  1. Jun 4, 2010 at 12:26 PM
    LVTacoma
    LVTacoma [OP] Well-Known Member
    R/R'd the front shocks with 5100's. Wasn't too hard and took me about 2 hours, but I need to do the rears today. I'm not mechanically retarded as you can tell but just to clarify, the rears simply bolt on and off with the ass end in the air correct? Usually the most simple of mods/mechanical work ends up being the worst somehow so I wanted to double check that the rears really are just jack-unbolt-remove-install-bolt up-jack down.
    Searched with no real avail. unless someone can link me a thread. Thanks fellas
  2. Jun 4, 2010 at 12:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Jack it up and place frame on jack stands, remove the tires, replace shocks, and re assemble. Much easier than the fronts.
  3. Jun 4, 2010 at 12:28 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yessir, they are extremely easy to do.
  4. Jun 4, 2010 at 12:29 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    the way i would do it set jack stands in front of the front leaf spring hanger and make sure the wheels are off the ground then put the jack under the middle of the axle and put a little pressure on it and then swap shocks. that's how i usually do them
  5. Jun 4, 2010 at 12:30 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    this.
  6. Jun 4, 2010 at 12:33 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    wow I didnt jack up the truck or take the tires off... i just unbloted the old and put in the new :D
  7. Jun 4, 2010 at 12:35 PM
    johnw
    john
    orlando florida
    no need to take tires off
  8. Jun 4, 2010 at 12:47 PM
    LVTacoma
    Sweet!. Just had to ask to make sure I wasnt going to run into any problems. I'll be sure to install the 'ziebutfor' when I do it today. Thanks guys
  9. Jun 4, 2010 at 12:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
  10. Jun 4, 2010 at 12:54 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Me 3
  11. Jun 4, 2010 at 2:25 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    dont forget about using an allen head on the top of the shocks. I tried to just turn the nut with a wrench and the hole shaft would spin :eek: (thats what she said)
  12. Jun 21, 2010 at 3:57 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    I just installed Bilstein 5100's on the rear & I was wondering if there is a torque setting for the top nuts. It seems like the bushings just get compressed to no end.
    Thanks,
    GA
  13. Jun 21, 2010 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    15 ft-lbs
