Rear Shock Relocation Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by mmcmahan2206, Aug 29, 2012.
  1. Aug 29, 2012 at 7:54 PM
    mmcmahan2206
    mmcmahan2206 [OP] Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    So my leaf pack hit and bent in the side of my rear shocks after wheeling up in the mountains a couple of weekends ago. I didn't think I did too much crazyness, but it still found a way to flex and rub, and now there's an ugly spot where the shock is dented in and scraped the paint off. :mad:
    My question is this: When relocating the rear shocks, what's the pros and cons to setting up your shocks like / \ compared to \ /???
    I relaize that if I went \ / way, then I could still use the top shock mounts and just relocate the bottoms to the axle (which would be easier). But I just wanna know what's best.
    Thanks in advance for all the helpful info! ;)
  2. Aug 29, 2012 at 7:54 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Thought you were getting a Dodge??? :D
  3. Aug 29, 2012 at 7:56 PM
    mmcmahan2206
    McCall, Idaho
    Man!!! You guys aren't gonna let me live that down, huh?? :(
  4. Aug 29, 2012 at 7:57 PM
    Max-4_Yota
    Michael
    South Carolina
    Squattin'
    Joking.....but probably not. :p
    Personally i've never seen shocks mounted like \ /. Not sure if that would even work.
    And from what i've read mounting them like / \ gives you more flex but makes the shocks less effective.
  5. Aug 29, 2012 at 7:59 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    What's "best"?
    Changing shock angle has several notable effects. What do you want the shocks to do? Provide more travel? Just clear the leaf springs? There are a lot of pluses and minuses to consider.
    Inboarding at the bottom and outboarding at the top is NOT advised.
  6. Aug 29, 2012 at 8:00 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    mounting shocks like this is bad \ / it will dampen you when the truck goes up and down, but will do nothing to dampen lean and swaying side to side. like this / \ will get you the clearance you need as well as a little extra travel.
  7. Aug 29, 2012 at 8:01 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    also, while doing this / \ will help, it lessens the shocks dampening ability. not a big deal, you just need to realize you are a little more limited if you like to wheel fast.
  8. Aug 29, 2012 at 8:02 PM
    jandrews
    He will also get a lot less dampening with this configuration and sway/body roll with loads or towing could be problematic. He would need to compensate by going to a stiffer valving in the shock, or adding another suspension component like airbags/timbrens.
    Even then, with stiff dampening, his truck might still have trouble dealing with loaded situations. But yes, he would gain rear axle travel provided his leafs/bumpstops don't limit it first.
  9. Aug 29, 2012 at 8:03 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    noted that just afterwards, probably while you were typing
  10. Aug 29, 2012 at 8:05 PM
    jandrews
    Yeah, saw that afterwards. Happens :notsure:
  11. Aug 29, 2012 at 8:07 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    if nothing else, it just reinforces the statement.
  12. Aug 29, 2012 at 8:16 PM
    jandrews
    Agreed.
  13. Aug 30, 2012 at 8:27 AM
    mmcmahan2206
    McCall, Idaho
    So I've been talking to a guy at AllProOffRoad that questioned me on why I'd want 4 shock brackets instead of 2 and just reuse the top mounts while only relocating the bottom mounts onto the axle. And I've only really seen the \ / pattern, and am being told that the / \ pattern works fine, which is why I ask.
  14. Aug 30, 2012 at 8:40 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    All Pro makes shock brackets? I mean, i know they have the tools to, i just didn't know they did make them. what they may be telling you is to move the bottom mounts inwards jsut a little. our shocks actually sit tilted in at the top just a little from the factory, so he may be telling you to take them from / \ to | |. move the bottom mounts in a couple inches to get vertical shocks.
  15. Aug 30, 2012 at 8:52 AM
    mmcmahan2206
    McCall, Idaho
    Ok, that makes sense. And keep the one shock forward and one shock backward setup?
  16. Aug 30, 2012 at 8:57 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    correct. and based on the dent you posted the picture of (fairly minimal), you really don't have to move them over far, which would help keep the handling pretty much the same as what you have now.
  17. Aug 30, 2012 at 9:26 AM
    mmcmahan2206
    McCall, Idaho
    Ok, gotcha! Thanks for all the helpful info! :D
  18. Sep 5, 2012 at 9:03 PM
    mmcmahan2206
    McCall, Idaho
    And now I can finally do the u-bolt flip mod! Woo hoo! Ordering parts tomorrow! ;)
  19. Sep 6, 2012 at 2:06 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    ^ to avoid shock body dents, utilizing the oem configuration,
    made by contact with the leaf spring...
    I spaced mine inboard 5/8"
    * mine are the bilstein 5125 (8" n 8.5") shocks (up to 3" lift)
    But this would work for other similar length shocks.
  20. Sep 6, 2012 at 7:14 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    I've done the same as Tacodell before doing my shock relocation. Make sure to add a larger bump since there is more leverage on the upper mount after the mod.
