Rear Shock relocation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwikvette, Jul 30, 2019.
  1. Jul 30, 2019 at 11:32 AM
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    I've seen the various threads where people have done a rear shock relocation mod from either; the BAMF kit (the cross member section with multiple spots to mount your shocks to) and the DIY setup that consists of a custom cross member section and one spot to mount the top of your shocks.
    Unfortunately, I don't have the tools or know how to make my own crossmember, and I only plan on learning how to weld in the next year. The BAMF kit would be perfect but it's no longer available.
    I'm posting this thread because I'm curious about a different setup that's available - Anyone familiar with it?
  2. Jul 30, 2019 at 1:45 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Depends on the type of wheeling you do. IMO, the BAMF kit (which I was also sad to see that it's no longer available) is better for articulation because you can run longer shocks without cutting into the bed. But it doesn't dampen wheel movement quite as well, so it's better for slow rock crawling type stuff. The slower you go, the less vital damping becomes. I had this type of setup on my 1st gen 4Runner and it worked well for the type of wheeling I do, but definitely had body lean on the road. My cross member was just a 1.5" tube welded between the frame, with holes drilled for the mounting bolts.
    I remember seeing a thread fairly recently from a guy that did the outside the frame rail conversion on his first gen. iirc, the guy had to run wheel spacers and even then the shocks were still extremely close to the tires and to the frame. Too close for my comfort...
    Area51Runner and turbodb like this.
  3. Jul 30, 2019 at 8:32 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    There's going to be nearly as much work with that Wheeler's kit as there is doing a custom cross member. I mean, the only extra thing you'll need with custom is the ability to cut a piece of round tube. And for that, all you need is a sawzall...
    Personally, I'd save about $400 and do the custom way. That'll buy you a welder to do it even.
    Couple things that might be useful for you:
    How-To: Toyota Tacoma Rear Shock Relocation - Determining Leaf Spring Cycle and Mount Positioning
    You can print this out and have a guide as to what you need in order to do the mod.
    Tacoma Rear Shock Relocation - Fabrication...and Failure
    My story, where I didn't correctly follow the steps above, which resulted in re-doing the work with a bit more TW-provided knowledge under my belt. (which I covered in https://adventuretaco.com/tacoma-rear-shock-relocation-scrapping-the-first-attempt-and-trying-again/)
  4. Jul 30, 2019 at 8:42 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That's just a total chaos kit, which will still require welding. There's a few people on here that run them.
    I'm not a fan of running shocks outside the frame on a 1st gen. There's just not enough room to make it work. You'll end up rubbing the shock even with tires sticking out way past your fenders. I would only consider them if you're running 265 or narrower tires, or have a wider axle than stock.
    Archive garage recently came out with a similar kit, and they have a thread with some good discussion on running shocks outside the frame.
    I would recommend the DIY route and follow @turbodb 's writeup. It's not a very difficult fabrication project, and if done right will offer you more performance than even a dialed mid travel front can deliver.
    Area51Runner likes this.
  5. Jul 30, 2019 at 11:38 PM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I'm running the Total Chaos outboard kit. Check out my build thread.
    I don't rub the shocks with 285 tires, 2.125'' shocks, and 1.25'' wheel spacers.
    frenchee and Kens04Taco like this.
  6. Jul 31, 2019 at 11:26 AM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    What kind of difference did you notice in the way it rides on/off road? Were you able to discern characteristics between the relocation and the overall upgrade to a better shock?
  7. Jul 31, 2019 at 11:58 AM
    jbrandt
    Justin
    I'd guess that's pretty hard to discern. Looking at his project, he changed all the variables at once, so kind of impossible to tell which variable made the most difference.
    That said, shocks will typically be the primary place you see the most improvements. Just adding upgraded shocks in the stock location will be a HUGE improvement. Relocating them is really just a way to squeeze out a little bit more performance for some situations, like wanting to get more wheel travel.
  8. Aug 1, 2019 at 5:11 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    The relocation didn't move the shock mounts all that much. What it did allow was for slightly longer shocks - 10" vs. the standard ~8" or so.
    As such, the shocks themselves are the place I see the difference. I get a bit more travel, but it's not like I'm flexing a ton further than I did previously.
  9. Aug 1, 2019 at 5:12 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    :gossip: They're talking about 1st gens. Totally different animal.
    rlx02 and jbrandt like this.
  10. Aug 1, 2019 at 5:13 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    2nd gen and therefore irrelevant to what works on a 1st gen.
    frenchee likes this.
  11. Aug 1, 2019 at 8:28 PM
    jbrandt
    Justin
    You did move your shocks into a parallel configuration (both leaning back) instead of the fore-aft configuration like stock. That's a fairly major change, but I believe this change is more likely to affect axle wrap than overall handling.
  12. Aug 1, 2019 at 8:57 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Exactly. A bigger change handling wise would have been outboarding the frame, or doing a / \ configuration - those would have affected stability/roll more than what I did.
    jbrandt[QUOTED] likes this.
  13. Aug 1, 2019 at 9:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @dlo13 should edit your post to delete those pics?
    Thanks to everyone else for posting on here; as I mentioned I will learn to weld in the year to come so either a cross member, or mounting outside of the frame, will require welding and I understand that.
    With that being said, my use won't be rock crawling at all. Just want to gain some more travel during the slower drives when we're out doing some dispersed camping.
    Just trying to get talked into one way or another...
    turbodb and jbrandt like this.
  14. Aug 2, 2019 at 4:13 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
  15. Aug 2, 2019 at 7:55 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I think I was the last guy to get the BAMF shock relocation bracket. He had one left and it had a minor defect resulting in a discount.
    That said, It works pretty well, but the holes used for adjusting the shocks don't allow for enough compression (Mounted more l l than / \ ) I'm running a 12" Fox and in order to get the shaft sitting at close to 6" of compression and 6" of rebound, I can't use the outer most holes. So the inner holes are all I can use. If I try to use the next set I'm left with around 3" compression and 9" of rebound.
    The full custom route will be the best way to go. You can cycle the suspension and be sure to get the most travel out of your shocks that way...
    Omicron6 likes this.
  16. Aug 28, 2020 at 8:57 AM
    Brahms
    Brahms Well-Known Member
    Houston, TX
    2004 Tacoma DCSB 4x4 SR5 V6 TRD
    If you had to do this all over again would you still go this route? I’m looking to purchase ADS 2.5” coilovers with remote reservoir and clicker for the front from Headstrong Off-road. Hopefully they go on sale. For the rears, I’m guessing I need to special order the 2.5” shocks with welded lower rod end directly from ADS?
    turbodb[QUOTED] likes this.
  17. Aug 28, 2020 at 9:17 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    If I had to do this again, I’d do exactly the same thing. :)
    In fact, I did do it again on @Digiratus truck, and he’s enjoying it as well as far as I know. He setup there is the same, though he got clickers and bypasses on his 10” shocks.
    Mike also got clickers in front, but he got them from MCM I’d recommend that route for you too, as Matt provides nice brackets and a good mounting solution for the front resis.
    Brahms[QUOTED] and Digiratus like this.
  18. Aug 28, 2020 at 9:41 AM
    Brahms
    Houston, TX
    You’re definitely the inspiration for what I want to accomplish. I’ll check out MCM. I’m also going to use your guide to do the Tundra brake swap.
    Unfortunately I live in an apartment complex and don’t know how to weld so I’m going to have to pay someone to do that part.
  19. Aug 28, 2020 at 9:46 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, no shop can be tough, and makes it hard to learn something like welding. Luckily, it's a pretty easy job, so you should have no trouble finding someone to do it.
    And by all means - reach out if you have questions about the Tundra upgrade, or want to grab a brake line kit.
    Brahms[QUOTED] likes this.
  20. Aug 28, 2020 at 9:48 AM
    Brahms
    Houston, TX
    How much would it cost for your help?
