Rear shock removal - alternate method
Discussion in 'Suspension' started by TacoBow, Nov 30, 2010.
  1. Nov 30, 2010 at 7:29 PM
    TacoBow
    TacoBow [OP] Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Rear shock replacement... generally a simple, straight forward job. Not something I was planning on doing, but something that I discovered needed done. Not a big deal right? Well, even though the drivers side gave me some grief, it wasn't too bad with basic tools. Here's my alternate method...
    Note: None of the names were changed in this story to protect anyone, since I was the only one involved. :D
    On with the story;
    It was a dark, rainy night... a curvaceous female figure under the pale glow of neon street sign. She was wet, yet looked SMOKIN' hawt as I rolled by in my Taco... wait, wrong story...
    Doh, yeah that's right... shocks. This one was seeping oil -
    I found it purely by accident, having removed all the stock alloy wheels for powdercoating. A wee bit of oil 'round the back of the shock body. Now's the best time to get a new pair bolted on. So, after my newest Tacomaworld buddy, ( props to Special_K ) hooked me up with a sweeeeet deal on a pair of stockers with 4K on 'em, I set to swap them out. A couple wrenches and we'll be done in about 30 minutes. Or not...
    Using the flat spot atop the shock rod, (after slipping the proper sized ratchet wrench on the top shock nut), I clamped on a genuine pair of Vise grips making sure not to trap the wrench below, and went to the task of removing the top shock nut...
    Alas, the nut was strongly opposed to this. In fact it was so tight that I was unable to prevent the shock rod from spinning in the shock body. I did make a few adjustments to snug up the Vise grips, but quickly realized that I was about to spin that flat spot right off of the top of the shock rod. Ewww... that's not good. Hmmm... let's apply some HEAT!
    I had already slid the blue plastic dust boot down the shock to allow me to visually inspect the shock rod... more so to keep an eye on that shock rod to determine if it was staying put during the failed upper nut removal attempt. This also kept the torch flame from igniting the plastic cover.
    I'm without a pic of this step, as I was holding the torch and unable to snap an image while keeping the flame off of other flammable hard parts under the truck. The gas fill tube is on this side, and even though far enough away, both hands doing work was the safer alternative. I got the nut as hot as I could, near to the point of catching the rubber shock bushings ablaze, but could still not budge that upper shock nut. :mad:
    Now since the shock was already defective, I could have torched that shaft and nut right off. I chose not to, even though packing a wet rag around that plastic wire loom would have worked to keep harmful sparklies away. My wife would have been none too pleased with the foul smell of burning rubber in the garage. On to plan B...
    As we know, the shock is shot anyway, so I'm none too worried about marking up the shock rod... Hi Ho Vise grip direct connect here -
    *** Sorry, no pic of the connect, please superimpose Vise grip grotesquely attached to the shiny shock rod in the visual aid above ***
    Ok, one hand on the Vise grip after applying enough closing force to squeeze juice out of a rock, and the other on the wratchet wrench... 1, 2, 3... (insert nut dropping strenuous sound here...)
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    v
    FAIL!!!!
    V
    V
    V
    V
    V
    V
    V
    SING IT WITH ME! - You spin me right round baby right round... like a record, er, I mean shock rod, baby, right round... spinning round shock rod...
    (dammit)
    Ok, mild frustration... that shock rod will not stop spinning in the jaws of the Vise grip.
    I put them on so tight that I could barely get them off. To my surprise, not a single mark was left on that shock rod. All I can say is that thing has to be a hardness level that superceedes a wedding prick on honeymoon night.
    Ok, that obviously isn't going to work either... let's go to plan C.
    Now this is something I've done before, yet not always a good move, 'specially if the shock was not leaking. These guys are under pressure, (altho this one ain't due to the leak), so binding it up may not be a safe thing to do. Here's what I did...
    Apology for no pic of this technique, which again requires two hands. With the top shock nut refusing to spin off, I removed the bottom shock mount bolt. This shock took nada effort to compress, simply collapsing about 4 inches before anything that remotely resembled damping began. Yep, it's toast. So, pulling it away from the axle, I proceeded to force the shock into a bind, pulling it away from the frame to "pinch" the shock rod in hopes to hold it fast while tugging violently on the ratchet wrench with my free hand. Drum roll...
    BAM! The 2nd verse of that same song suddenly came on the radio! An OMEN! Ok, I kinda made that part up, but you have to admit it would have been kewl if that song was really on the radio at that moment. :cool:
    Plan D! Where's my little grinder... we are about to make an attachment point on the shock rod... changing it from this -
    To, (grind, grind, spin shock rod 180 degrees and grind, grind, grind some more), achieve this -
    So we can now attach our Vise grip on the flat spots like this -
    And we can finally spin that F%z5@!!!! shock nut off the top like this -
    So the shock will come out like this -
    MAN... ain't that a kick in the... well... it's outta there! :woot:
    As seen here, the top of the shock rod flats are rather small, which didn't offer much in the way of gripping surface for the Vise grip -
    Using the grinder allowed me to create a larger flat area on the shock rod via removing a bit of material directly opposed from one another. This gave the Vise grip a solid connection point and prevented the shock rod from turning when applying pressure to the top nut via ratchet wrench.
    The little flat tab on top of the shock rod didn't fair too well with the twisting, much like my wife's face would have been been twisted had I filled the garage with burning shock rubber smoke. I've learned that's not a good thing. Now I suppose I could have ground the top nut and the shock rod off too, but applying that much friction to the shock rod would have risked igniting the shock mount rubbers, which was something I was trying to avoid.
    The two rear shocks after removal, (having about 52,000 miles on them), were laid side by side for comparison. Notice the drivers side is vertically challenged, having zero damping for approximately the first 4 inches of its compression travel. The remaining stroke of the shock was best likened to that of a wet sponge -
    The install went well, since the old passenger side shock was obviously scared by the a$$ whoopin' the drivers side shock took via the grinder, and it came off without a fight. A happy Tacoma with Special_K shocks looks like this -
    I'm anxious to get my wheels back from the powdercoater so I can take 'er for a smooth ride!
    So, knowing that not everyone has access to a torch, (at least not an oxygen / acetylene rig) I figured this removal method using common hand tools that most of us already own was worth sharing here.
    I'll close by saying that I hope you don't have this issue with your shocks, but I certainly hope these little tips might lend ya a hand to make things easier if ya do. :thumbsup:
    Disclaimer - I agreed to pay myself prevailing wage for the job outlined above, (and yes, I may have farmed it out a bit), so as not to constitute the filing of a contract grievance after knowingly declining the use of stunt doubles in the replacement of these rear shocks. :)
  2. Nov 30, 2010 at 7:41 PM
    bobfm10350
    bobfm10350 Well-Known Member
    Deric
    Austin Texas
    06 PreRunner TRD Off Road
    Access Limited Tonneau, Hawk LTS Brake Pads, SP Performance Slotted Rotors, Goodrich G-Stop Brake Lines, Thule Roof Rack, Bilstein 5100s Front and Rear, Eibach Coil Springs, Cabela's Floor Mats, 265-75-16 Duratracs, Fog Light Anytime Mod, D-Rings Mod, USA Spec PA15 TOY Ipod Adapter, Gorilla Lock Nuts, K&N Drop-In Air Filter, Wet Okole Seat Covers Front & Rear, Toytec 1.5" AAL, Viper 5901 Car Alarm
    I had to end up doing the same sort of thing when I installed my rear 5100s. Everyone here made it sound so easy but it ended up being a real pita! Im glad im not the only one who had a hard time with it haha
  3. Nov 30, 2010 at 7:46 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I did the exact same thing!
  4. Dec 1, 2010 at 7:35 PM
    TacoBow
    Central PA
    I'm surprised that a TX raised truck would have given ya fits, just to say without all that DOT salt on the roadway like our buggies have to endure here every year. :(
    I see your ride travels in NY... so much like the climate here. Makes for the more often skinned knuckle modding as the odometer logs the winter weather.
    I like snow... just not fond of the metal effects compliments of the salt combating it on the traffic-way.
  5. Dec 2, 2010 at 12:33 PM
    Jim D
    Jim D Member
    Jim
    Newark,DE
    4WD 2.7AT SR5 excab
    New Firestone Destination AT tires
    I'm a newbie here-hi guys. I had the same job to do on another vehicle with similar challenges. I just used my sawsall right through the upper nut and shaft. Popped right off with no burning or cussing too loudly.
    Jim D.
  6. Dec 2, 2010 at 12:45 PM
    TacoBow
    Central PA
    Hey that's cheating man. Just think how few pictures you could have taken of that process.
    Not to mention it would have made for a real short post. :D
    Welcome aboard Jim!
  7. Dec 2, 2010 at 1:06 PM
    flightcancled
    Yeah I came really close to busting out the saw, really close!
    I love how this is really the "Road Salt Methods of Doing Things" thread.
  8. Dec 2, 2010 at 1:14 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    damn, I would have just used the angle grinder to cut off the nut on the top from the begining! When I did my AAL that little center pin was rusted in place and wasnt gonna come out so i went used a cut off wheele on the angle grinder and fixed it real quick :D
  9. Dec 2, 2010 at 1:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Same here, but I just just swazalled through the nut.
  10. Dec 2, 2010 at 4:31 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Have had to do the same thing... thats why I always always SOAK the threads in liquid wrench for a few minutes before removal.
  11. Dec 2, 2010 at 5:28 PM
    TacoBow
    Central PA
    Yup, I agree 100%
    ... and I put that in the original post,
    Would grinder wheelin' the top off smoked the shock rubbers? Maybe not, but then again your little lady might be a bit more tolerant than mine is to stinking up the garage. I've been married 19 years and I know what I can get away with. I'll put up with a little extra grinding vs. the risk of putting up with her bitching me out any day. LOL
  12. Aug 23, 2015 at 7:19 PM
    mtcarrio
    mtcarrio Active Member
    New Orleans
    2007 TRD Sport
    Skid plate, debadged
    My front passenger strut snapped this past week. I decided to buy and replace both strut assemblies. I also purchased two shocks for the back. I'm having the same problem as above! This is way more difficult than it should be! The bolts and shock stems spin in unison, i'm considering the angle grinder. Anybody know where to get two new bolts for my new shocks??
    New system:
    Front Suspension - Monroe Quick-Strut Loaded Strut ASsemblies
    Rear Suspension - Rancho RS5000
  13. Nov 25, 2017 at 4:05 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    The top tab sheared right off. Might need to cut...
    Edit: was able to use locking wrench to grab the upper part of the threads and get nut loose. Then had to use pipe wrench to hold the boot near the top when there were no threads left to hold as nut moved upward. Jacked up the threads, but not too sad about it considering they were hitachi stock shocks.
