Rear Shock Removal
Discussion in 'Suspension' started by cormudgen, Jan 22, 2012.
  1. Jan 22, 2012 at 12:27 PM
    cormudgen
    cormudgen [OP] Well-Known Member
    Doing my AAL instal now and am having trouble removing the rear shock. No matter what I do when trying to remove the top nut, it spins the nut and the center pin. I've tried using pliers to hold the center pice with no luck.
    I've also PB blaseted it to help break loose but also no luck.
    How do you keep it from spinnin?
  2. Jan 22, 2012 at 12:28 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    I used vice grips
  3. Jan 22, 2012 at 12:45 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow 4" bracket and 35s. MC rear AP front bumpers 5.29s locked
    Put blaster on it n let it soak. Shoulda put a crescent wrench or a 6mm wrench on to hold it if possible. More than likely both of those will slip eventually n you'll need vice grips. Don't booger up the threads though. When all else fails, heat the nut
  4. Jan 22, 2012 at 12:49 PM
    markc6606
    markc6606 Well-Known Member
    Pompano Beach
    '13 Off-Road
    Not sure what shocks you have, stock TRD bilsteins have 2 flat spots on top of stud for an adjustable wrench. 5100's have an allen screw to hold ont it so it wont spin when turning nut
  5. Jan 22, 2012 at 1:12 PM
    cormudgen
    These are stock TRD Off Road shocks, so there is no spot for an allen wrench. I've soaked it pretty dang good with PB blaster, and cinched down the vice grips as much as possible and still no joy.
    I can't hack it off as I'm intending to re-use the stock shocks.
  6. Jan 22, 2012 at 1:13 PM
    cormudgen
    What do you suggest to heat the nut? Unfortunately all I have access to is a hair dryer and I'm guessing that wouldn't do much.
  7. Jan 22, 2012 at 6:05 PM
    cormudgen
    I eventually got it with the vice grips, however when enough of the "head" wasn't showing anymore I moved the vice grips down to the sillver part of the shock. I know this isn't ideal but it was the only way I could get it loose. The other side seemed to go much smoother however. I'm not sure if this had anything to do with it, but i left the bottom pice of shock bolted in.
  8. Jan 23, 2012 at 11:43 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I ran into the same problem...not enough of the shaft showing at the top to put anything on it.
    I finally got out a cutting wheel and split the nut.
    Faster than anything else I tried.
  9. Jan 23, 2012 at 11:47 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    i used a grinder and saws all...easy enough
  10. Jan 23, 2012 at 11:59 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Same here, I ended up cutting them off. I cut the stud though since they were just going in the trash. Very dumb set-up on the Bilstein HD's in my opinion. The Allen bolt on the 5100's is a much better set up.
  11. Jan 23, 2012 at 12:08 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    If there are exposed rusty threads, I'll clean them up with a small wire wheel on the dremel. Then I PB it, tap it a few times and let sit for a while, then PB it again before attemping to remove it.
  12. Jan 23, 2012 at 12:13 PM
    cormudgen
    I was re-using the stock shocks so cutting was not an option. For whatever reason the passengers side went much smoother.
    Total time for AAL on driver side was 4 hours including 3 trips to Lowes...
    Total time for AAL on passengers side was 50 minutes...
  13. Jan 23, 2012 at 8:07 PM
    2 crown j
    2 crown j Active Member
    Jay
    Bothell,wa
    08 tacoma dclb 4x4
    I used chanel locks to hold the shaft from turning. I griped the shock about one inch from the top. You will able to feel were to grip then just grip and take the nut off.
  14. Jan 23, 2012 at 8:09 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Nice, good job man! Feels good huh? My stupid shocks did the same thing. The 5100s do have a better design at the top!
