rear shock replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ozmon420, Sep 28, 2013.
  1. Sep 28, 2013 at 6:33 AM
    ozmon420
    ozmon420 [OP] Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    just went to goodyear for an oil change, and they said I should replace my rear shocks. the reason he gave me was because I have 100k and that they would eventually mess up the wear of my tires. does he have a point? or is he just trying to sell me some shocks?
  2. Sep 28, 2013 at 9:09 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    He's bullshitting you. Shocks have nothing to do with the rear alignment
  3. Sep 28, 2013 at 9:44 AM
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    Make sure to have your blinker fluid flushed with Mobil 1 synthetic when you go back for your shock replacement.
  4. Sep 28, 2013 at 9:47 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    ha. and don't forget your sky hook and board stretcher.
  5. Sep 28, 2013 at 10:54 AM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Shocks that are completely worn out can allow your tire to bounce a bit on the road, sort of like tires being unbalanced. Same goes for running without shocks, which completely worn out ones are pretty much like anyway. That can cause premature wear. But are your shocks that worn out? Not likely. Do shocks wear out? Of course they do. Only the people who can evaluate your shocks in person can say if you need new shocks or not. I would not say mileage would be a determining factor, unless it's just an "advised" timeframe to change them.
    I'm sure he'd love to sell you some shocks, but I cannot tell you if you need them or not.
  6. Sep 28, 2013 at 10:59 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    X2
  7. Sep 28, 2013 at 11:01 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    He's likely bullshitting you but I'll second TxFireman.
    There is some truth to shocks and tire wear. Shocks dampen the up and down movement of the tire, in some cases with bad shocks or no shocks the tire will 'skip' down the road and you get "cupping", which is the uneven scallop type wear of the tires. Has nothing to do with alignment.
    However he's bullshitting you unless he can prove your shocks are bad.
    Bounce each corner of your vehicle real hard, if it bounces a couple times and stops, you're good. Any more and you should think about replacing them -- go some googling.
    I think everyones seen that car with bad shocks that hits a bump and continues to bounce and bounce and bounce for a half mile - LOL.
  8. Sep 28, 2013 at 11:02 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    100k? I'd replace them.
  9. Sep 28, 2013 at 11:03 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    If they do need to be replaced, don't pay someone to do it. The rear ones are so easy to replace....you really don't even need a jack.
  10. Sep 30, 2013 at 6:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    At 100K I would check them as mentioned above and replace them as needed.
  11. Sep 30, 2013 at 6:21 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    If you replace them go with 5100's all the way around :)
  12. Sep 30, 2013 at 8:13 AM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    my truck came with black toyota shocks, replaced with the Rancho MT7400. what a difference it made. i would guess at a 100k you probably need shocks and good monotube shock is best. Bilstein and Rancho make a great shock, just make sure it is a monotube not a dual piston shock. pushing down on the bumper did show the shocks to be bad, probably because i added an AAL. when i pulled the old off they were wore out and one was blown. hated it when Toyota put staggered rear shocks, doesn't make sense to me. i think it causes vibration problems.
  13. Sep 30, 2013 at 8:27 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    This ^^^^
    I have done it many times without a jack. The Bilstiens are pretty easy to compress so its no big deal.
  14. Sep 30, 2013 at 8:55 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    could you explain this for me?
  15. Sep 30, 2013 at 12:28 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Really easy. Less time to change rear shocks than the cabin air filter.
  16. Sep 30, 2013 at 12:44 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    One of your shocks mounts is before the axle and one side is behind the axle. Like forward slash and back slash from the side it looks like
    .......O
    The "o" is your tire. dots are the leaf springs
  17. Sep 30, 2013 at 12:58 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Haha, I had a similar thing happen recently. I took my truck to get the front lifted and the guy told me my front shocks were shot (it didn't matter because they were getting replaced anyway). But I wanted to keep them so I could sell them, and he was adamant that they were 'old' and shot and I wouldn't be able to sell them and that I might as well let him keep them. I don't think he looked at my odometer before he tried to BS me. The truck had less than 500 miles on it.
  18. Sep 30, 2013 at 1:15 PM
    RearViewMirror
    Craig Christ
    Oops!:eek:
  19. Sep 30, 2013 at 5:06 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Sorry, no I understand how the shocks are mounted. Why do you hate it and why do you think it causes vibrations? Why doesn't it make sense to you?
  20. Sep 30, 2013 at 5:27 PM
    ozmon420
    miami, florida
    08 tacoma
    how much are 5100's?
