Rear Shock Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myclejay, Feb 23, 2017.
  1. Feb 23, 2017 at 10:08 AM
    myclejay
    myclejay [OP] Well-Known Member
    SD
    Had new tires put on recently on my 2007 Pre-Runner and noticed a strange squeaking sound coming from the rear area. Had the rear leaf TSB done but did not address the sound. The tech at he dealership said I had a rear shock that was leaking. I've zeroed in on the sound and it is the drivers side shock so I plan on replacing both. The local Midas quoted me $450-500 over the phone with parts and $110 without. I did say "just the rear" so maybe they're quoting me for all 4. Regardless, I see that a pair of Bilstein 5100s are about $144 on Amazon. Are there any other parts that I might need for replacing both rear shocks or does each shock come with the applicable mounting as well as any other parts? Thanks.
  2. Feb 23, 2017 at 10:14 AM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    All you need is just the shock and the rear is extremely easy to replace.
  3. Feb 23, 2017 at 10:16 AM
    whiskeytacos
    whiskeytacos Well-Known Member
    New York
    '14 DCSB Off Road MGM
    OME 886 springs on 90000 struts Total Chaos UCA OME Dakar + AAL energy suspension steering rack and sway bar bushings SCS SR8 wheels Cooper ST Maxx 285/85r16 Pelfreybilt IFS skid plate Pelfreybilt hidden winch mount broken ass winch Softopper All Pro Off Road OTT pack rack
    I didn't even lift the rear end or remove tires to replace my rear shocks. Super simple task.
  4. Feb 23, 2017 at 10:37 AM
    myclejay
    SD
    Just looked it up and no kidding it's easy. Thanks.
