rear shock size?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Littlebro 5, May 7, 2011.
  1. May 7, 2011 at 9:03 PM
    Littlebro 5
    Littlebro 5 [OP] Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    what size shock will work great with a 3" leaf lift. extended length, travel, collapsed length?
  2. May 7, 2011 at 9:08 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    8.5"? Is the lift on? If so measure from shock mount to shock mount and report back here. Anyone know what the stocks are? Iirc it's 6" of travel but idk for sure, so technically you'll need a 9" but idk of anyone that makes a 9" or our trucks
  3. May 7, 2011 at 9:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    IIRC, the stock ones are almost 8"
  4. May 7, 2011 at 9:24 PM
    malander
    max
    01 limited trd 4x4
    Haha as always I need some correction
  5. May 7, 2011 at 9:30 PM
    malander
    max
    01 limited trd 4x4
    So chris if expo leaves lift me 4.5" in the rear how do 10" stroke shock work for me? I've already lifted and measured and they will have ~5" of travel up and down. Is it just dependent on where the compressed length starts?
    Op sorry for the thread jack, but hey free bump for you. What set up are you going to run in the rear?
  6. May 7, 2011 at 9:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure I understand your question...
  7. May 7, 2011 at 9:52 PM
    malander
    max
    01 limited trd 4x4
    Idk if it's really a question. But the shocks I'm running are only have 2" more travel than stock, but the expos are probably gonna net me 4.5". I guess I'm just coming to the conclusion that it doesnt technically matter what stroke the shock is, just where it's mounted and what length it is at ride height.
  8. May 7, 2011 at 10:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It matters, and you should be OK with that set up, but you need longer bump stops.
  9. May 7, 2011 at 10:13 PM
    malander
    max
    01 limited trd 4x4
    Yeah I know I'll have more travel with the pack, but hypothetically say it only gave me 2" of travel or something. Idk. And bumps are on the list, probably going 4.5" because I can't find any 5" or 5.5" but I'll probably just measure it out once everything else is installed
  10. May 8, 2011 at 1:05 AM
    Littlebro 5
    Tyler
    Wilsonville or
    Ok yeah i am doing bilstein shock's but i don't want to hit shock before bump stop but get the best travel?
  11. May 8, 2011 at 2:57 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    your best bet would be to look into Icon for the rear shocks. They are good for a 3" lift. And they ride good. down side is they are a bit pricey. Or you can get some bilstein 8 in shocks.
  12. May 8, 2011 at 3:05 AM
    03taco
    03taco Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    ok lol now im interested cause mine are about due for changin
    i got me a six inch fabtech and i want to switch to coil overs in the front if possible and get me some new shocks for the rear best choices would be and this is on a semi tight budget due to baby on the way
  13. May 8, 2011 at 7:52 AM
    malander
    max
    01 limited trd 4x4
    With the rear shocks still in measure from eye to eye. That measurement should be in-between the compressed and extended length of the shocks that you will buy.
    Then take the shocks out and jack up one side of the truck until a rear wheel gets off the ground. Measure from shock mount to shock mount (eye to eye, just no shock in there) on the side that's in the air.
    Take that second measurement and subtract the first measurement from it, then multiply by two (because the shock has to go up AND down).
    Now you have the travel number to determine what length shock you need.
    Quick example:
    Ride height measurement=20"
    Extended measurement with now shocks is 25"
    A shock with a 10" stroke is required, it's compressed length should be 15" and extended length 25"
  14. May 8, 2011 at 7:55 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
  15. May 8, 2011 at 10:38 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Stock travel on a first gen is 6.5"
    Most go with an 8" or 8.5" travel when they do the standard 1.5" to 1.75" rear lift that comes with many of the 3" front lifts...
    If the OP is lifting the front 3", his rear lift is likely within the 1.75" lift and not the 3" as that would end up with the rear higher than the front...
    As for the 9" travel shock, the Bilstein 5125 comes in a 9.24" - part number BE5-A463-H6 (15" collapsed - 24" extended)
    Although, there is a better alternative which is the Bilstein 7100 10" short body - part number AK7110SB (14" collapsed - 24" extended)
