Rear Shock suggestions/recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grichg, Jan 25, 2020.
  1. Jan 25, 2020 at 12:12 PM
    grichg
    grichg [OP] Well-Known Member
    rich
    Laguna Beach
    11 Tacoma 4x4
    Camburg 3.0 Coilovers Camburg A-arms All Pro rear bumper CBI Front Bumper LED Light Bar and PODs and some other misc
    Hello,
    Have 2011 4x and currently have the Fox 2.0 but they've blown a seal again. They are years old and have been rebuilt. Want to just replace at this point and not sure I want the same.
    My truck has Deaver built Leafs along with Camburg UCA and CO.
    Are the Bilstiens good or the Fox are still a good one to go with? Dont need Resevoirs or super expensive ones as the mojority is on road with Baja trips sprinkled in.
    thanks in advance
  2. Jan 25, 2020 at 12:19 PM
    Shellshock
    Iowa
    I’ve been running Fox 2.0 on the rear for almost 3 years and 98,000 miles and haven’t had any issues.
  3. Jan 25, 2020 at 12:22 PM
    grichg
    rich
    Laguna Beach
    11 Tacoma 4x4
    Ive had mine for about 5 years and lots of miles. Leaked once before, had rebuilt and was under the truck doing oil change yesterday and noticed it was spewing again.
  4. Jan 25, 2020 at 12:30 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I ran Icon VS 2.0 shocks for almost 7 years with no rebuild and no issues. A few wheeling trips each year interpersed with salty winters. Icon uses nitriding on the steel shaft instead of chrome plating, so it's resistant to stone chips and corrosion, and you can run them without a protective boot or "shin guard". Eibachs are inexpensive and allow for good droop travel:
    grichg[QUOTED][OP] likes this.
  5. Jan 25, 2020 at 12:39 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I absolutely love my Icon 2.0s.
    Dramatically improved the ride over stock.
    Close to 80,000 miles on mine. No rebuilds.
    They have held up much better than my front fox 2.5s.
    Icon has way better corrosion resistance. Other than some scratches they still look brand new after a WD40 wipe down.
    I can't say the same for my Fox's.
    grichg[OP] and 3JOH22A like this.
  6. Jan 26, 2020 at 8:38 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Fwiw, I've had a rear 5100 leak so bad I thought I was losing axle fluid. Replaced under warranty at no cost. I see some fluid around the shock boot again now. Seems like no shock is immune to failure.
  7. Jan 26, 2020 at 8:41 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    One thing to check is the extended and collapsed lengths of the shock match your leaf pack. If your blowing seals that much maybe they are too short? Do you do alot of offloading (cycling the rear suspension)?
  8. Jan 26, 2020 at 10:43 AM
    grichg
    rich
    Laguna Beach
    11 Tacoma 4x4
    Mine could be from not being long enough for the height the Deaver springs created. In any event I think I am going to try the Icons...
