Rear shock top bolt -- spinning..help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kyebasse, Dec 9, 2021.
  1. Dec 9, 2021 at 10:38 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Installed cross thread?
  2. Dec 9, 2021 at 10:41 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Terrible design?? :confused::confused:
    Maybe somebody over there doesn’t know the score…
    Special Tool 8-A:
  3. Dec 9, 2021 at 10:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Once you get it to the top, as far as it will go, you can hold the flats with smaller pliers, or you can grab the shock with your hand, or you can put the vice grips on anything below if you are not reusing the shocks.
    SR-71A likes this.
  4. Dec 9, 2021 at 10:43 AM
    Kyebasse
    Kyebasse [OP] Jd
    K
    21 Tacoma TRD Off-road
    Good one
  5. Dec 9, 2021 at 10:44 AM
    Millhouse516
    Millhouse516 Traveling by Tacoma
    San Diego
    Silver 2019 DCSB SR5
    5100's - Icon AAL - RTT - DIY Awning - DIY Mods
    Maybe cut off the top bushing and clamp the vice grip there...below the nut.
  6. Dec 9, 2021 at 10:46 AM
    Kyebasse
    Kyebasse [OP] Jd
    K
    I'm saving the shock. I though about a thin pillar that can go between the two openings but couldn't find something that small. May be there is some kind of tools.
  7. Dec 9, 2021 at 10:47 AM
    Kyebasse
    Kyebasse [OP] Jd
    K
    That's my next best measure
  8. Dec 9, 2021 at 10:48 AM
    Kyebasse
    Kyebasse [OP] Jd
    K
    Did you check the picture? This won't work
  9. Dec 9, 2021 at 10:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The only thing is the special tool that @Hobbs posted above.
    If the shaft or body is exposed, you could wrap it with something protective and then use vice grips on it?
  10. Dec 9, 2021 at 10:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That will hold it until there is nothing left to hold. By then, there would only be a turn or two left on the nut. Some strong needle nose pliers held vertically could do similar.
    SR-71A likes this.
  11. Dec 9, 2021 at 10:52 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If thats true, you need needle nose pliers (preferably vice grips) to hold the shaft either from above or below the nut. Then continue backing the nut off those last few threads.
    Alternatively get one of those rubber-strap pipe wrenches to hold the shock body still. I feel your pain, but this really isnt as big of a deal as its being made out to be haha.
    tonered and Superdave1.0 like this.
  12. Dec 9, 2021 at 10:52 AM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Once the nut covered up the flat spots I had to have at it with an air ratchet. That was the only thing would spin the nut off faster than the shaft would spin I suppose.
  13. Dec 9, 2021 at 10:52 AM
    SR-71A
    Zack
    Southern Maine
    Yes vertically is the key. Like pliers pointing down at the top of the shock...
    tonered[QUOTED] likes this.
  14. Dec 9, 2021 at 10:53 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    that is literally the tool designed to hold these.
    44-16 Taco, DWD484, whatstcp and 3 others like this.
  15. Dec 9, 2021 at 10:56 AM
    #35
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Seriously. Try a 1st Gen Sequoia or my 100 series Land Cruiser. Way way more difficult to deal with. Tacoma is a breeze.
    JJ Customs[QUOTED] likes this.
  16. Dec 9, 2021 at 11:16 AM
    #36
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'm confused. So you have held the flat spot and can get the nut to run up until it hits the vicegrips? In the pic theres plenty to still hold on to.
    Have you tried an impact?
  17. Dec 9, 2021 at 11:26 AM
    #37
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Are you removing the top bolt with the truck jacked up? If you are then you are putting pressure on the threads (pulling down) and that cause it to bind.
    Make sure the truck is on the ground and do it, once you get past the tension of the bushing, the bolt will spin off by hand.
  18. Dec 9, 2021 at 11:35 AM
    #38
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Wheels on the ground, on of mind has resistance until the very last thread. I used vice grips on the top of the shock body to hold it. It was a minor PITA because the plastic sleeve was attached there also. Still, I was able to get it apart without too much trouble.
  19. Dec 9, 2021 at 11:39 AM
    #39
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Once you get the nut up to the last bit of threads, use this to reach down and hold that flat spot, to run it off the rest of the way... you'll need a tiny pair.
  20. Dec 9, 2021 at 11:40 AM
    #40
    5nahalf
    Erik
    Minnesota
    I only say that because if he cant get it off the normal way with such clean threads already, then he needs all the help he can get.
