Rear shock upgrade after 6" lift?
Discussion in 'Suspension' started by 07speedwayblue, Aug 23, 2011.
  1. Aug 23, 2011 at 6:20 AM
    07speedwayblue
    07speedwayblue [OP] Well-Known Member
    michael
    nineveh, Indiana
    07tacoma sport 4x4 doublecab
    Jason Rage lid, husky floorliners, Procomp 6" stage 1 lift , bilstein 5100 upfront, 33x12.50r17 MT ATZ tires MT 17x9 Classic Locks,stainless steel brake lines,N-Fab ss nerf bars,smittybuilt grille saver, Amp bed extender,Mbrp cool dual t409 exhaust. KCHiLites Daylighter Driving Lights 6", Pioneer AVH-P4300DVD, HD Tunner, Rear Camera, Focal K2 Power 6.5" Component Speakers Front/Back, Infinity Kappa Four and Kappa One Amps, Infinity Kappa 10" DVC Subs,PowerStop Drilled/Slotted Rotors ,PowerStop Heavy Duty Towing Brake Pads, Blue Painted calipers.
    Anyone have a part number for a set of bilstein 5100 to be used in the rear to replace the procomp shocks that come with the procomp 6" stage 1 lift?
  2. Aug 30, 2011 at 9:47 AM
    07speedwayblue
    michael
    nineveh, Indiana
    BUMP! No one has upgraded their rear shocks? I hate having a bilstein 5100 upfront and a procomp white shock in the rear. HELP!!!!!!!!! :confused:
  3. Aug 30, 2011 at 9:48 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Check out my build. 12" stravel fox stem tops.
  4. Aug 30, 2011 at 9:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    You need a 5125 or 5150 in the rear. How much rear lift did it get? 4"?
  5. Aug 30, 2011 at 9:49 AM
    wannatoy570
    wannatoy570 Well-Known Member
    Dave
    Lock Haven, PA
    05 Toyota Tacoma SR5
  6. Aug 30, 2011 at 9:52 AM
    07speedwayblue
    michael
    nineveh, Indiana
    It got the add a leaf and a block , I believe it was to total 4". The truck sits a little higher in the front , but my stock rear springs saged some.
  7. Aug 30, 2011 at 9:55 AM
    wannatoy570
    Dave
    Lock Haven, PA
    You probably want to upgrade your leafs and get rid of that block, then you can get the shocks you need.
  8. Aug 30, 2011 at 10:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    For your current set-up you could get F4-BE5-6248-H5 this but you will need the eyelet adapter. It's the 5125 (custom length 5100)
    If you wanted the 5150 you'd need F4-BF5-A196-H1this again the adapter also.
    They will accommodate up to 6" of lift (between 3-6").
  9. Aug 30, 2011 at 10:06 AM
    07speedwayblue
    michael
    nineveh, Indiana
    I`m going to do that down the road when I go to coilovers up front. Thats going to be a little while though. Thanks for all the input!! :D
  10. Aug 30, 2011 at 10:08 AM
    07speedwayblue
    michael
    nineveh, Indiana
    Thanks a MILLION 98tacoma27 !! You the MAN!!!!! :thumbsup:
  11. Aug 30, 2011 at 10:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just make sure you're bump stops are big enough. The adapters add extension but they take away from compression and I don't want to see you bottom out the shock. (I think you'll be fine but just airing on the side of caution).
  12. Aug 30, 2011 at 10:13 AM
    07speedwayblue
    michael
    nineveh, Indiana
    Thanks! This my wife`s truck it sees nothing but pavement and very little offroad.
  13. Aug 30, 2011 at 10:33 AM
    07speedwayblue
    michael
    nineveh, Indiana
    Were would one buy a set of those pin to eyelet shock adaptors?
  14. Aug 30, 2011 at 1:01 PM
    98tacoma27
    Ben
    Not Beech Creek
