Rear shock upper rear shock mount torque
Discussion in 'Suspension' started by WTtoolman, Jul 7, 2011.
  1. Jul 7, 2011 at 6:27 PM
    WTtoolman
    WTtoolman [OP] Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    I've been rearching and cannot find what the torque for the upper rear shock mount is supposed to be! I installed the 5100, Eibach, and rear AAL today and would really like to know. I managed to find torque specs for everything else, so I give up, what is it? Any help is greatly appreciated!!
  2. Jul 7, 2011 at 6:29 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Tight then half turn snug :notsure:
    When in doubt ^ :D
  3. Jul 7, 2011 at 8:37 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    When I was a kid, my dad taught me to tighten them until you see the bushings start to compress a little.
    The theory has been working just fine ever since then.
  4. Jul 7, 2011 at 8:42 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Yeah 15 ft lbs if ya got a crows foot. Ya gotta be able to hold the shock piston rod in place to tighten it. What you can do to be safe is while it's jacked up tighten the bolt til you can see two or three threads showing, then lower your truck to the wheels and see if the bushings are compressed then it should be tight enough, but give it at least another half turn just to see how tight it is. 15 ft lbs isn't much, it's just a lil more than hand tight.
  5. Jul 7, 2011 at 8:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You didn't torque the U bolts to 37 did you ?
  6. Jul 7, 2011 at 8:50 PM
    WTtoolman
    William
    Omaha, NE
    No, I used common sense and just tightened them until snug. I wasn't worried about the nuts coming off because they come with a new nyloc nut. I just wanted to be on the safe side!
  7. Jul 7, 2011 at 8:53 PM
    OZ-T
    Peter North
    British Columbia
    :anonymous: uh ..... ya ... me too , that's what I did . What kind of an idiot would simply beleive the Haynes and torque their U bolts to 37 .
    Idiots
  8. Jul 7, 2011 at 8:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "snug" is no good for the U bolts. Tighten them to 80ft-lbs or so.
  9. Jul 8, 2011 at 5:21 PM
    WTtoolman
    William
    Omaha, NE
    The U-bolts I torqued to the facory spec of 75 ft-lbs, it was the top ones that I "snugged."
  10. Jul 8, 2011 at 6:10 PM
    OZ-T
    Peter North
    British Columbia
    The FSM says 37 lbs , that's why I asked
