Rear shocks for 4-6 inches? Gen 2 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jcole, May 7, 2017.
  1. May 7, 2017 at 4:00 PM
    Jcole
    Jcole [OP] Member
    2014 Silver TRD Double Cab
    What type of rear shocks are you using for 4 to 6 inches of rear lift 2 gen tacoma
  2. May 7, 2017 at 8:36 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    Fox remote res
  3. May 7, 2017 at 8:38 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Bilstein b110
  4. May 8, 2017 at 7:56 AM
    reefnfeef
    reefnfeef Well-Known Member
    Bridger, MT
    '14 Pyrite Mica DCLB TRD Sport
  5. May 14, 2017 at 4:06 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    King remote resi with adjusters.
    click the link below this.
  6. May 14, 2017 at 8:16 AM
    Pigpen
    Dan
    Northwest Montana
    This is what I run too
  7. May 14, 2017 at 9:46 AM
    TWENTYCO
    TWENTYCO Tree top flyer
    Tim
    North FL
    2015 TRD Off Road 4X4 Acess Cab
    Plenty mods on many vehicles since 1982. Current: 15 Tacoma 4X4 V6 TRD OR Access Cab Pyrite Mica- Icon full stage 7, All-Pro APEX sliders & rear Expedition Springs + custom Tampa Springs leaf spring upgrades, Timbren bump stops, u-bolt flip, Road Armor front stealth winch bumper & rear steel, Warn Vr 8000, Nitto Terra Grappler 285/75/r16, Off Grid Engineering Dual Battery system, SPod 6 switch, 2 pairs Rigid D2 spot & flood in bumper, ARE Expedition Cap, bedglide,Tru Cool 45K GVW add on transmission cooler, Re-gear to 4.56, rigid rear bumper floods, scan guage II, rigid ditch lights. full size spare on matching factory wheel, seat mods/insert, CB w/magnet mount.
    Combination of All Pro Expedition springs & Icon Stage 7 w/2.5 Omega Bypass Remote Reservoir Rear Shocks
