Rear shocks question???
Discussion in 'Street Trucks' started by Brendo Ballz808, Feb 19, 2013.
  1. Feb 19, 2013 at 10:23 AM
    Brendo Ballz808
    Brendo Ballz808 [OP] Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    I bought my Tacoma with 2" blocks and this pass weekend i added in 4x4 leafs
    Future plans is to notch the back and add 4" blocks
    I took out the bumpstop and put in low pros but i bottom like crazy!:(
    I wanted to know any recommendations for rear shocks to stiffen the ride
    QA1's are out of the question at the moment but will probably be in the future
    The truck is an 05 Base and prolly has the original shocks on em
    Mahalo
  2. Feb 19, 2013 at 3:43 PM
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Did you measure how much drop you have in the rear (compared to OEM)? I'm assuming that with the 4x4 leafs and 2" blocks, the rear drop is about 3"?
    A better solution than using shocks to resolve your temporary bottom-out issue would be to put in air bags. The cheapest route would be to install the kit and use a bike pump or the like to adjust the pressure, as opposed to buying an on-board compressor. Shocks are not designed to prevent your vehicle from bottoming-out, they're there to stabilize the leaf springs.
    Even so, QA-1's are your only option for adjustable shocks as far as I know. There might be air shocks that fit the Tacoma, but I can't imagine they're any cheaper than the QA-1s and I wouldn't recommend them.
  3. Feb 19, 2013 at 8:49 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Yeah I think it's about a 3-3.5 drop in the back
    Seems like the 4x4 leafs are actually softer but that's just me
    I'll prolly run some air shocks if my old ones from my other truck fit as a temporary
    Try a save up for the djm kit with the notch
    Thanks tho
  4. Feb 19, 2013 at 10:34 PM
    NoelsMyKuya
    NoelsMyKuya Well-Known Member
    Aaron
    San Deezy
    05 Access Cab sr5
    Very clean taco you got there! Nice wheel choice too.
  5. Feb 20, 2013 at 1:13 AM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Thanks bro
    I bought the truck with the wheels
    Im looking to change the tires however
    Currently running 255/50/19 Toyo's
    its to tall for a drop though :p
  6. Feb 24, 2013 at 8:12 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Why are QA1's out of the question?
  7. Feb 24, 2013 at 8:14 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    i would contact djm and see what they recommend
  8. Feb 25, 2013 at 10:23 AM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Only for the moment
    eventually when I'm finish with the whole drop they will be apart of my kit if not just the Calmax rears
    I'm just gonna save to buy everything one time
  9. Feb 25, 2013 at 1:55 PM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers
    This looks familiar... :spy:
  10. Feb 26, 2013 at 12:25 AM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    haha almost like braddahs
    btw love your build
    are you djm up front?
  11. Feb 26, 2013 at 6:54 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not yet, currently just 3 inch drop blocks and QA1s.
  12. Feb 26, 2013 at 10:03 AM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    It would be nice if it didn't cost and arm and a leg:eek:
    I miss how easy my other trucks were to drop just torsions and blocks haha
    it will sit real nice when you do it though!
  13. Apr 28, 2013 at 8:30 AM
    Mr.Schertz
    Mr.Schertz Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    What tires and wheel combo do you have? How much did it set u back? Im trying to decide what to get
  14. Apr 28, 2013 at 10:19 AM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    The 20s I got I bout em for $800 with tires but they go for $3000 brand new
    20x9 up front +20 mm offset
    20x10 put back +35 mm offset
    The front and rear both sat flush to the fender at stock height when I dropped it the front wheels came in a bit
    Was running 245/35/20 up front and 275/30/20 out back
    I'm not gonna run those wheels I'm gonna be running 18x9.5 +22 all around on 225/45/18 all around should sit flush to the fender
