Rear shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xTACOMAx, Aug 14, 2013.
  1. Aug 14, 2013 at 9:44 AM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    I have the rough country 3" lift on a 2007 toyota tacoma prerunner and the lift comes with rear shocks and two 2" blocks I was wondering if I can run with shocks if I take out the 2" blocks?
  2. Aug 14, 2013 at 9:46 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Not sure your question? You wanna be two inches higher in the front by taking out the 2" block? I wouldn't recommend doing that just upgrade the block to a progressive leaf pack or AAL.
  3. Aug 14, 2013 at 9:46 AM
    Large
    Large Red
    You can you will just bottom out over bumps maybe, and if you wheel. If you are going back to a stock rear end why not check out the free stuff thread, there is rear shocks there all the time, in fact I just threw my rears away because no one wants them.
  4. Aug 14, 2013 at 9:48 AM
    xTACOMAx
    07 prerunner TSS
    No my truck had the rake where it sits lower in the front but with I put the lift on it lifted the truck but it still has the rake and was wanting to take out my blocks so it would be level but I didn't know if I could use the shocks or not
  5. Aug 14, 2013 at 9:53 AM
    xTACOMAx
    07 prerunner TSS
    Well instead of taking out my blocks would y'all know any way for me to lift the front so it will be level with the back?
