Rear Shocks
Discussion in 'Suspension' started by SMG26, May 16, 2010.
  1. May 16, 2010 at 7:13 PM
    SMG26
    SMG26 [OP] Well-Known Member
    Woodstock,GA
    06 Prerunner TRD Offroad
    Injen CAI, JBA exhaust pipes 2.5" w/magnaflow muffler, Doug Thorley Long tube headers, URD MAF CAL and O2 sim,Access roll up cover, AVS Wind deflectors, coverking seatcovers, grillcraft upper/lower grille, Halo projectors w/6000k HID and pop lock on tailgate.
    I have an 06 DC trd off road with a toytec aal 2" of lift with stock shocks. I want to upgrade the rear shocks so they do not top out over bumps. I was looking at the 5125's. But was wondering what valving/travel would I need to get. Or would the 5100's be good enough and not make that horrible thud when I go over bumps.
  2. May 16, 2010 at 7:18 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    5100s accommodate up to 2" of lift w/o issue. those should be fine until you go over 2" of rear lift
  3. May 16, 2010 at 7:21 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    And a cheap alternative (temporary of course) shock extenders from toytec until you can save up for some better shocks
  4. May 16, 2010 at 7:23 PM
    SMG26
    Woodstock,GA
    So the 5125 would be a little over kill for my set up?
  5. May 16, 2010 at 7:25 PM
    The_Hodge
    SC
    ^^ yes, IMO
  6. May 16, 2010 at 7:27 PM
    08pretaco
    az
    Ya just go with the 5100's. It'll be a huge improvement over stock and you should be pretty happy
  7. May 17, 2010 at 12:38 PM
    SMG26
    Woodstock,GA
    I was talking too Sonny DSM via email and said the 5100's would be cutting it close with my 2" lift. He recommended going with the 5125 9" travel but I need a stem conversion?
  8. May 17, 2010 at 1:14 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    ^^ click-able ^^
  9. May 19, 2010 at 9:34 PM
    lextech
    lextech Member
    Are the rear 5100's longer than stock?
  10. May 19, 2010 at 10:49 PM
    08pretaco
    az
    I don't think so on the length issue just differently valved, more agressive
