Rear Shoulder Belt Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mcman56, Jul 17, 2016.
  1. Jul 17, 2016 at 3:43 PM
    mcman56
    mcman56 [OP] Member
    2016 Tacoma
    In order to get a little more interior space, I removed the rear seats in my extended cab Tacoma. I would also like to remove the rear shoulder belts but don't see how to get to the top mounts. There is a little pop in insert with "air bag" molded in. I removed the insert and the bolt behind it but the trim still seemed firmly attached. Any ideas on how it comes out?
  2. Aug 4, 2016 at 9:05 PM
    wudbuchr
    wudbuchr Well-Known Member
    Linnie
    Lexington, TN
    2016 (7128A) BBP 4x2 - TRD Sport Access Cab
    * Clear Bra (full front) * BBP (8T0) Side Body Molding * Tinted Windows with AWS window shades * Romik Running Boards * Color matched Undercover Lux bed cap and BedRug bed liner * MobTown Locking bed storage doors, Tailgate skin and cap * Chrome Tailgate Script lettering * G-Tec Fab Door Sill Protectors and OEM Mud Guards * Fumoto Valve * ScanGauge-II * LED Interior, Stop, tail, Bed, OPT7 LED H11 low beam and fog lights * WeatherTech floor mats * Clazzio seat Covers * Removed jump-seats & rear seat-belts * Sound deadened back wall, rear posts, rear doors and front doors with a layer of RAAMmat, a layer of Ensolite, and a layer of EzCool * Insulated the roof with two layers of EzCool * GT series Image Dynamics speakers (6x9 fronts, 6.5 rears) * Audio Control DQ-61 DSP, 5-channel amplifier and sub woofer. * Redline Tuning Quick Lift Elite hood struts * Thinkware F770 (Dual) Dashcam with Cellink Battery B * Lexus SmartKey Transmitter and Emergency Key
    There is a horizontal line about 12 inches from the top of the rear post, where
    the two post panels clip together. Remove the 10mm bolt you found behind the
    pop in insert with "air bag" on it. The top piece clips into the lower/bottom
    piece. You will need to pull the gasket loose from the body (door frame) and
    remove the plastic molding from the inside edge of the cab roof line. Where the
    rear doors lock to the roof line are two 10mm bolts you will need to take out and
    remove that plastic piece too. Having done that, you will be able to pull the plastic
    panel free of the cab body. Pull gently but firmly. The panel is held in place with
    plastic clips and should any of them not come free when the panel comes off, be
    sure to remove them and place them in the corresponding spots on the panel
    before reassembly. Once you have removed the plastic panel(s), removal of the
    shoulder belt mechanisms is easy. Reverse the steps to reassemble and you're done.
  3. Aug 4, 2016 at 9:20 PM
    Username:
    Username: I wear adult diapers at music festivals.
    CJ
    Pacific USA & Canada
    16 TRDS 6M w/ TRD Humidor
    "She's into malakas, Dino."
  4. Aug 4, 2016 at 9:22 PM
    wudbuchr
    Linnie
    Lexington, TN
    Deep thought for such a shallow mind!
  5. Aug 4, 2016 at 9:24 PM
    Username:
    CJ
