Rear slide window leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Mar 24, 2011.
  1. Mar 24, 2011 at 5:43 PM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Hello,
    I washed my truck the other day and the noticed that there was some water behind the back seat coming from the rear slide window. I hosed off the back window on the shower setting from the hose. Didnt check it in rain yet. Is this normal?
  2. Mar 24, 2011 at 5:48 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Not for me. Check the gasket for damage?
  3. Mar 24, 2011 at 5:52 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
    I've read on here that the third brake light can leak.
  4. Mar 24, 2011 at 5:55 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmm....never thought about that? Might wanna look into this.
  5. Mar 25, 2011 at 6:39 AM
    magnum922
    The gasket is perfect. The truck has 1400 miles on it.
  6. Mar 25, 2011 at 6:42 AM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    Friend of mine with a 2009 had water issues when it rained very heavy. Told him to take a hose and spray the back window and look inside after and walla.......water was getting in........brought it to the dealer and had the rear window replaced and resealed.
  7. Mar 25, 2011 at 7:09 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Did you check it? Only 1400 miles makes it more likely to be a manufacturing defect...
  8. Mar 25, 2011 at 7:23 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I'd be driving straight to the dealership and make them fix it.
  9. Mar 25, 2011 at 8:14 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dealer time
  10. Aug 25, 2011 at 3:31 PM
    bob8294
    bob8294 Member
    2021 F-150 2.7L
    Had the same problem with my 2011. Drove it off the lot, second day it was home decided to take it to the car wash after it rained, found the middle rear window was leaking water rather badly. Brought it back to the dealership to get it replaced, on the way there the brakes seized on the drivers side, upon inspection the dealer found that the e-brake assembly was missing a bolt which fell out and gouged the drum/shoes as well. They fixed that and the leaking window at the dealership, found out that they had replaced the entire rear window since they can't just change out the middle window. I got them to test their replacement, and their head detailer found that the catch on the middle rear window was leaking water this time. After speaking to upper management at the dealership and Toyota Canada I've just been getting the run around, they're finally looking at giving me a solid rear window after I had suggested that, however from the sounds of it they want to charge me for it, definitely not going to happen. I think there's a engineering defect in the 2011's in that rear window, i dont know if the design changed from 2010-2011. Youre definitely not alone though.
  11. Aug 26, 2011 at 9:49 AM
    magnum922
    I found the source of my rear slider window leak. It was latched when it leaked but then I found out you have to move it about 1 or 2 mm after latching before it would stop leaking.
  12. Aug 26, 2011 at 11:36 AM
    roberth2334
    roberth2334 Active Member
    Rob
    Western Ky
    2010 Tacoma DC TRD
    Had same issue and dealership is putting new sliding window in. They are replacing the entire back window. From what I was told this is a fairly normal problem. I have 11000 miles on my 2010
  13. Nov 17, 2011 at 7:50 PM
    nutydiver
    nutydiver New Member
    Belleville, Ont. Canada
    2011 tacoma trd 4 door
    I found my 2011 Tacoma's rear window was leaking after washing it. It had only a few miles on it. I took it back to the dealer and they replaced the whole window assembly. I checked it after getting it back and found it was still leaking. Took it back and they verified it was leaking. they checked another new truck on the lot with same results. So I am waiting to hear from Toyota Canada on this. Seems to be a design problem. Perhaps we should look at launching a class action law suite over this.
