Rear slider failed, any suggestions on proper replacement techniques
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Always Thinking, Jul 13, 2025 at 3:45 PM.
  1. Jul 13, 2025 at 3:45 PM
    Always Thinking
    Always Thinking [OP] Well-Known Member
    AZ
    2023 Tacoma TRD PRO, Metallic Grey. Love it! 2nd owner, bought it from a friend.
    Lighting. Wheels/tires. Bed Step. Rock Sliders. Locking Gas Cap.
    Hello all, anyone had the small back sliding window fail? My neighbors 2021 SR5 Tacoma V6 regulator failed. We removed the plastic panels from behind the rear seats, then pulled the regulator, the cables on black spool were all twisted. The replacement part is under $75 so that's good. Anyone have installation tips?
  2. Jul 13, 2025 at 4:00 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    eurowner and Chew like this.
  3. Jul 13, 2025 at 8:47 PM
    Always Thinking
    AZ
    Thank you TA2016.
    The window is fine and we can push it open and close. The problem is we would like to see if anyone has replaced the regulator. When we removed the old regulator there is a gear that may or may not needing adjustment before putting power to it. I'll continue my search on Google.
  4. Jul 14, 2025 at 9:59 AM
    TA2016
    Oregon
    Not seeing any videos on the gear. Here is another TW thread with some bits of info. Good luck.
    https://www.tacomaworld.com/threads/power-rear-sliding-window-fail.822416/
