rear sliding window fix? broke it again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TacoRidah, Sep 9, 2013.
  1. Sep 9, 2013 at 9:34 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    thought i fixed the stupid locking panel piece but yet again it has come off :mad::mad: anyone know of a fix for this? i am now missing the top screw, only the bottom stayed on the lock panel. not into someone breaking in due to POS factory decisions of how to go about locking a rear sliding window. :mad::frusty::frusty:
  2. Sep 9, 2013 at 11:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And place a rod in the sliding window channel.
  3. Sep 10, 2013 at 6:27 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I've never even opened mine...
  4. Sep 10, 2013 at 9:41 AM
    07TacoRidah
    got any recs on what glue to use? I see most of those two bottled ones around, but ... hmmmmm :confused:
    I read about that on here somewhere. My problem is, I don't use my a/c (the free on (sp) makes me VERY sleepy), and I am at most (since it's still summer) opening and closing the window each time I'm in the truck (at night it's open/close but for the most during the day I have to have it open to let out the heat). Is there something that won't seem "tedious" (sp) each time I'm in the truck?
  5. Sep 11, 2013 at 11:37 AM
    Partzguy
    Partzguy Well-Known Member
    Don
    North Texas
    2015 DCSB TRD Sport 4x4
    +1
  6. Sep 11, 2013 at 12:15 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Wut?
    The ac just blows cold air...no freon is expelled through the vents. If you had that happening, youve got issues with the system and it would cease to cool the air...
  7. Sep 11, 2013 at 4:17 PM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Two of the most effective glues I've come across are PL Premium construction adhesive, and ShoeGoo (and it's various differently-labeled tubes......which are all actually the same stuff). The PL Premium is about the best of the best, but it dries tan. The ShoeGoo has proven itself to hold glass together when dropped onto a driveway from 20 feet, and it's insanely flexible, and excellent at taking heat cycling -- I use it to mount a couple of items to my windshield, and I can't get them off now (I've tried).
    You may want to visit BenWa's powered rear slider thread to see what glue he uses there, since I forget the name off-hand. Supposed to be awesome stuff.
    Super glues (and its variants) are intended almost exclusively for plastic-to-plastic bonding, since C-A dissolves plastic (like welding metal) -- it doesn't do much for anything else non-porous. Epoxy works for a short time, and on stuff that doesn't see regular heat cycling or any movement/vibration. JB Weld is great stuff, but is generally only used for metal applications.
  8. Sep 15, 2013 at 12:56 PM
    07TacoRidah
    ... :( I get sleepy from cold air.
    HELL YEAH!!! thank you. THIS IS INFO! big ups man. :cool:
