Rear sliding window gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icarus II, Oct 6, 2020.
  1. Oct 6, 2020 at 7:41 AM
    Icarus II
    Icarus II [OP] Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    I opened the window yesterday and it seems the lower channel gasket isn't adhered to the frame any longer. The window rocked side to side.
    I slid the gasket back to the passenger side and the window slides properly. Should there be an adhesive to hold the gasket in place?
    Can someone post a pic of the lower gasket for me?
    TIA, Keith
  2. Oct 16, 2020 at 6:47 AM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    In case anyone else EVER runs into this, the gasket has a rib that rides in a groove in the window frame. i guess it just shrunk with age. A little weatherstrip adhesive between the side of the gasket and frame channel fixed it right up. Cleaned the inside of the gasket and lubed LIGHTLY with silicone spray on a paint brush. All's good.
    Blockhead likes this.
