Rear sliding window problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a.s., Dec 15, 2016.
  1. Dec 15, 2016 at 2:34 PM
    a.s.
    a.s. [OP] Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    The little plastic thingy that "locks" the rear window came unglued almost 5 years ago. I had every intention to glue/stick it back on but then I lost the damn thing. Luckily I never had any issue just sliding the window open with my hand. Unfortunately all the rubber seals around the window are now tearing off.
    Anyone else have theirs repaired. Idea on cost or fixes?
    Thanks
  2. Dec 15, 2016 at 3:22 PM
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    cut a stick to fit in the slot along the rear window you can use that as a cheap anti-theft devise other than the broken latch you can try to glue it back on, what the worst that happens you need to go buy a new one.
  3. Dec 15, 2016 at 7:25 PM
    a.s.
    Stack
    NY
    I couldn't care less about the latch. It's the weather strips that need replacing. Maybe I should change out the entire window? :confused:
  4. Dec 15, 2016 at 8:10 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I've only opened that piece of crap a couple times for no real reason. I'd rather have a solid rear window, yet it's considered an "upgrade". If it was powered I might use it more often, but I doubt it.
    calico likes this.
  5. Dec 16, 2016 at 3:11 AM
    a.s.
    Stack
    NY
    You never realize how much you need something till it's gone! There's been a half dozen times I had to slide a long 2x4 through that window. Now I don't even open it for fear of tearing out the rubber strips completely. :(
  6. Dec 16, 2016 at 10:28 AM
    jesseunvoas
    Jesse
    08 TRD SPORT
    I get ya now, mine does that as well just pop the seal back in as long as it's not completely broken off otherwise you can cut a small strip of weatherstripping to fill the gap and glue it to the stationary window portion
  7. Dec 28, 2016 at 6:59 AM
    Aron
    Aron New Member
    06 Sport DC, Speedway Blue
    Jesse - How do you pop it back in? I have a 2006 Taco and mine just rolled out of the channel for the first time. Can't figure out how to get that bigger back in.
  8. Dec 28, 2016 at 10:54 AM
    jesseunvoas
    Jesse
    08 TRD SPORT
    Just use your keys or a paint stir stick, mine was torn so i have a homemade rear window lock which is just a wooden paint stir stick. When I use the rear window for the dog to get some air I have to push the seal back in every time.
  9. Dec 28, 2016 at 1:29 PM
    Aron
    Aron New Member
    Ohhh... got it. Thanks. I jammed it back between the glass panes, but if anyone has a suggestion to actually seat it back in the channel, I'm all ears!
  10. Dec 28, 2016 at 2:54 PM
    jesseunvoas
    Jesse
    08 TRD SPORT
    I'm thinking it's moulded and if it came out like mine you need a new one if It bothers you enough.
  11. Dec 28, 2016 at 6:48 PM
    Pigpen
    Dan
    Northwest Montana
    SOLID REAR WINDOW FTMFW!!
    Actually, I wish I had a slider :pout:
  12. Dec 28, 2016 at 8:48 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    My truck came with the sliding rear window. After about a year I put a sticker on the outside slider. After a few times of opening the slider it ripped the seals out. Guess the sticker was just enough to fill in the gap between the slider and fixed glass. Had the back window replaced with a solid piece of glass. Much happier now since I don't have to worry about someone trying to break in through the slider.
  13. Dec 29, 2016 at 6:01 AM
    jesseunvoas
    Jesse
    08 TRD SPORT
    Better yet I wish they had a roll down rear window like some Nissan trucks I've seen.
  14. Dec 30, 2016 at 2:24 PM
    a.s.
    Stack
    NY
    I know I'd regret not having the window. My rubber seals are pretty much f\_/cked. I'd be shocked if water wasn't already getting into the back cab. I guess my only option is to go to Toyota and see what they'll charge. :pray:
