rear speaker
Discussion in 'Mr Marv' started by Burgman, Apr 22, 2009.
  1. Apr 22, 2009 at 1:23 AM
    Burgman
    Burgman [OP] I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    MrMarv ive read that you dont like rear speakers b/c it throws off the i dotn know the word but the sound up front, and u usually say put a really nice set up front and cheaper ones in the rear.
    What about a midbass in the rear door of my dbl cab?
    And im going to get you my info to u about those baffles but the store i was ordering from took to long and now im reevaluating what im going to get
    thanks in advance
  2. Apr 22, 2009 at 9:18 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Authorized Hybrid Audio Technologies Dealer (www.hybrid-audio.com) ARC Audio amplifiers, subs, processors now available! Helix Processors now available! For you super high end guys Brax amplifiers will be available soon! (PICS HERE and new website coming soon with Subwoofers, Amplifiers, Wiring Kits)
    Hey Burgman..Actually I do like rear fill but I don't use tweeters behind me since those higher frequencies are what will cause the problem with the soundstage. I typically like to use just a midbass with the same tonal characteristics as the fronts however I have also been known to cut the tweeter wires on coaxials and only use the mid when necessary. :D (I have a simple technique I can teach you that allows the rear speakers to actually "enhance" the front stage as opposed to detracting from it)
    BTW, I forgot to let you know that I did in fact start another group buy on the Hybrid Audio gear.
    http://www.tacomaworld.com/forum/gr...ents-baffles-group-buy-4-21-09-5-21-09-a.html
  3. Apr 22, 2009 at 8:55 PM
    Burgman
    Stephen
    Ric VA
    Im not sure if ill be able to have enough money for the Hybrid's but if i did what would be a good speaker in the rear that matches up with them, it would have to be pretty cheap
    thanks again Marv, your an amazing asset to TW
  4. Apr 22, 2009 at 9:12 PM
    Burgman
    Stephen
    Ric VA
    Another thing i cant seem to find any info on the power needs of the clarus system
  5. Apr 22, 2009 at 10:20 PM
    Mr Marv
    Marv
    Thanks for the kind words Burgman! :) You have probably noticed around here that I preach how important the front speakers are for any system you want to sound great. Also, my recommendation is to always get the "best" you can for the front since one "excellent" set of speakers (installed properly of course!) will sound better than two "OK" sets of speakers. When budget requires me to I have used several different inexpensive coaxials for "ambient fill" including Pioneers/Eclipse/Alpine/DLS/Polk etc and all have worked out very well when used for "ambient fill" with the Clarus. The key is I cut the tweeter wires (I have found that the tweeters are usually the worst part of most inexpensive coaxials anyway!) and I have a couple of very simple tuning tricks to get them to enhance the front stage nicely. Also, I always use a 5 1/4" since they are much cheaper than 6.5's and you won't need the additional cone area anyway.
    Almost forgot, if you are unable to do the entire amount for the group buy up front just contact me and I will work something out for you. :)
    I have found that with just 75 watts of "real" power these bad boys will sing louder than most anybody would ever listen! :)
  6. Apr 22, 2009 at 10:42 PM
    Burgman
    Stephen
    Ric VA
    i couldnt ask you to put me on installment payments, i should have the money b4 the group buy ends just waiting on an order cancellation refund
  7. Apr 22, 2009 at 10:55 PM
    Mr Marv
    Marv
    Sounds good and I wouldn't have a problem with installments if needed! :)
  8. Apr 23, 2009 at 10:13 PM
    Burgman
    Stephen
    Ric VA
    Marv it doesnt look like ill be able to spend that much on those speakers so my question is do you prefer 6.5 over 6x9?
  9. Apr 24, 2009 at 8:42 AM
    Mr Marv
    Marv
    No worries! When using a sub I prefer to have 6.5" components but if not I use a good set of 6x9's to get more bottom end. :) In that case I also prefer 6x9 components because they usually have a "better" tweeter with mounting cups to allow installation flexibility and adjustable passive crossovers that allows you to tailor the level between the mid/tweeter for your specific application. :)
  10. May 1, 2009 at 12:01 AM
    Burgman
    Stephen
    Ric VA
    I have another question. I plan on getting Boston Acoustics SL60 6.5 components that have a power rating at 80 watts rms 220 watts max, but the amp i was going to get is a 4x50. So my question is: will that amp be powerfull enough to properly power the speakers and if i have it at full power is that bad for it?
  11. May 1, 2009 at 11:31 AM
    Mr Marv
    Marv
    That amp will power those speakers "properly" however with the gains set using a 0db reference you would not get full output from the speakers. There are some "tricks of the trade" that allow you to "squeeze" more power from an amp however I don't think I will post them because if not utilized properly someone may end up blowing their speakers and I don't want to be responsible for that! :eek: Also, any "good" amp installed properly will run at full power for quite some time without any issues. :)
