Rear Spring Harsh Ride
Discussion in 'Suspension' started by waterwolf603, Aug 25, 2011.
  1. Aug 25, 2011 at 7:14 AM
    waterwolf603
    waterwolf603 [OP] Well-Known Member
    New Hampshire
    2011 SR5 v6 4x4
    So I brought my 2011 SR5 Taco in to Toyota yesterday for a "Harsh" ride and this is what they said they were going to do
    rear assembly spring (both sides)
    alignment
    front Toe-in
    Front Camber
    Front Caster
    Not being huge into the mechanical aspect of things (go easy I am learning slowly) will this affect the height of my truck at all? If so how much and how much to add new shocks and the works to give myself a 3'' lift? Any help would be appreciated I am still a green horn and just started doing minor mods to Miranda (my trucks name)
  2. Aug 25, 2011 at 7:28 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    What kind of Harsh ride how did the truck feel?
  3. Aug 25, 2011 at 7:34 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    it felt weighed down and not leterally "bottoming" out but that kind of feeling.... Essentially I want to lift it and am wondering if any of what the dealership is going to do will aid that process
  4. Aug 25, 2011 at 7:37 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    being i admittedly dont know what
    front Toe-in's
    Front Camber's
    Front Caster's
    was just curious and I assume when they say springs they are talking about leaf springs?
  5. Aug 25, 2011 at 7:41 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Did they say if they were going to replace the springs? From what you said it dont sound like that is what there going to do.
  6. Aug 25, 2011 at 7:45 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    ya I believe they said upgrade the springs or replace I cannot remember which one... There definately was no mention of shocks or anything tho. Thats why I am curious to see if it will affect the height of the truck or not
  7. Aug 25, 2011 at 7:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If they are doing alignment then they may be swapping base shocks to yellow bilsteins...if OP doesn't already have them.
  8. Aug 25, 2011 at 7:47 AM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    On the 11 they will not replace the shocks. Shocks are fine. And if they do replace the springs you may get 1.5 or 2 inch of lift.
  9. Aug 25, 2011 at 7:47 AM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    The Camber and toe-in stuff have to do with the tilt/angle of the front wheels and is adjusted during alignment. They're most likely addressing the TSB that toyota issued for the Tacomas and will replace the rear leaf springs with a 4 pack. Since they're replacing the springs, they'll have to do the alignment as well.
  10. Aug 25, 2011 at 7:47 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Spring replacement is 3 leaf pack out back for a 4 leaf pack............which should have been coming on these trucks since 2005.
  11. Aug 25, 2011 at 7:51 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    Gotcha thank you all I appreciate the help, trying to learn as much as I can. This is my 2nd Truck but the 1st one I am actually in to and plan to mod the shit out of
  12. Aug 25, 2011 at 8:02 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    any recommendations on shocks or a 3'' lift kit that will not break the bank, my truck is a daily driver aswell fyi
  13. Aug 25, 2011 at 8:04 AM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    884's with 5100s set at 0 with a top spacer
  14. Aug 25, 2011 at 8:07 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    how much do you think that would run me and any recommendations on where to go to get them?
  15. Aug 25, 2011 at 9:08 AM
    Blackshirts
    TX
    09 PreRunner
    Stuff
  16. Aug 25, 2011 at 9:22 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
