Rear Spring TSB Done: How to Balance the Front?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plannerman99, Feb 2, 2010.
  1. Feb 2, 2010 at 4:15 PM
    Plannerman99
    Plannerman99 [OP] Well-Known Member
    So Cal
    Our Adventure Vehicle
    Got the rear spring TSB done last week and took the truck out to Calico on Saturday. The rear end is a bit stiffer (I noticed when dropping off rocks and ledges) but handled very well. However, I noticed that the front end was bobbing around more than in the past. I believe the stiffer rear springs were transferring energy to the stock front springs and I thinking I'll probably need a heavier duty front spring.
    Any thoughts or experience on this?
  2. Feb 2, 2010 at 4:25 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    TSB with Belsteins 5100 adjustable shocks up front.
    I have mine set at .85. The shocks are much better firmness, matching the back.
    The TSB raised the back about 1 inch, so hense the .85 setting.
    I believe the 1.75 setting is also quite common if trying to level the truck out more.
  3. Feb 2, 2010 at 4:26 PM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
    i did not notice that.
    did they do an alignment?
    raising the rear of the truck will change the angles on the front, which is why you have to do a front alignment after rear suspension work. many people report they dont get it done when the tsb clearly calls for it.
    if not, i would go back and nicely demand they do it per tsb instructions.
    i do not think you need heavier front springs over basically an aal on a new pack. many will prob be jumping in saying to get blistien 1500's though to raise the front up a bit to match the rear.
    persoanlly id wait a while, the rear will sag some. id wait for the new pack to break in before making your decisions. i wouldnt want to match the front to the rear, only for the rear to sag back down some. you may indeed find the front is lower, and 1500's or aftermarket coils may be the way to go in the end though.
  4. Feb 2, 2010 at 4:33 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    I went with the Eibach 1.6" springs in the front after the TSB and I couldn't belive how much better it rides and feels over stock.
  5. Feb 2, 2010 at 4:40 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    same here...eibach and 5100 up front at the zero setting which gave me 1.6 inches of lift. Leveled out the truck very well. Not to mention it handles and rides better now.
  6. Feb 2, 2010 at 4:49 PM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    hey what did you tell the dealer to get them to do the TSB?
  7. Feb 2, 2010 at 4:50 PM
    Plannerman99
    So Cal
    They definitely aligned the truck - the steering wheel is a bit crooked now.
    I don't think I necessarily need front springs, either, but maybe heavier duty shocks. This isn't a matter of how the truck sits, I don't think, but dampening the energy transferred to the front end from the back axle.
    I'll look into 5100s... I like the idea of an adjustable ride height.
  8. Feb 2, 2010 at 4:52 PM
    skistoy
    Western New York
    with the billys, get a good alignment and thats it.
    i have had no vibrations, or rubbing issues at all.
    even on highway doing 75-80
  9. Feb 2, 2010 at 4:54 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I noticed no change in the front after the rear TSB spring install. The rear was stiffer and it does a good job. I felt no need to modify the front suspension.
  10. Feb 2, 2010 at 5:36 PM
    Plannerman99
    So Cal
    I told them the truck swayed like a drunken sailor when I had four bales of hay (~500 lbs) in the bed and, that when towing a trailor, the ride was rough and the rear sagged. Called Toyota first, but didn't really need that with my dealership.
  11. Feb 2, 2010 at 6:32 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    I noticed in my new 2010 that my rear end bounces around crazy. Would the tsb fix this? And if I plan I getting an aal with billies all around would I really need the tsb? My dealers being a dick about the tsb.
  12. Feb 2, 2010 at 9:06 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I told the dealer I put a quantity of 20, 40 lb bags of mulch in the truck and it bottomed out going over most any kind of bump. I told them it banged so hard I was concerned I was going to bend or brake something.
    The dealer jumped right on it.
