rear spring TSB only 3 leaves?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by krap22, Apr 23, 2011.
  1. Apr 23, 2011 at 4:42 PM
    krap22
    krap22 [OP] Well-Known Member
    I just took it in to the dealer complaining about the crappy ride with it loaded with my bike. They said they would take care of it with stiffer springs. Here are the springs they put on.
    I only count 3 leaves. It is stiffer than what i had. Before unloaded it was 7" above the tire. With my bike, it was 5.5". Now, unloaded, it is 7.5" and loaded it is 6.25". It is much better. I just wondered if they changed the spring pack they are putting in.
  2. Apr 23, 2011 at 4:46 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    it's supposed to be a 4 leaf pack, hmm
  3. Apr 23, 2011 at 5:12 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Should be 3 leaves and an overload
  4. Apr 23, 2011 at 5:21 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    here is mine...just picked it up this morning after they completedededed it
  5. Apr 23, 2011 at 5:21 PM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    could the difference you're seeing in ride height be the difference between worn leaves and new crisp leaves? sounds like someone made a mistake.
  6. Apr 23, 2011 at 6:42 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Definitely not the tsb pack
  7. Apr 23, 2011 at 6:49 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I fart in your dealer's general direction.
  8. Apr 23, 2011 at 8:15 PM
    WickedTaco
    WickedTaco Well-Known Member
    Aaron
    Treasure Coast, FL
    '11 Silver DC TRD OR 4x4
    iPod Interface, Bully Tailgate Lock, ScanGaugeII
    OP, the same thing happened to me and then I checked the part numbers on the TSB. There is a table that says part # being replaced and part number that is replacing. My dealer installed brand new 3 leaf packs with the same original part number. I went back with the TSB and read the instructions with the service writer. He shamefully admitted the mistake and they installed the correct 4 leaf pack. TAKE IT BACK!
  9. Apr 23, 2011 at 8:42 PM
    krap22
    awesome, i knew i was working with a bunch of idiots
  10. Apr 23, 2011 at 8:49 PM
    krap22
    does anyone know what the part number should be for the TSB pack?
    my invoice shows 48210-04550 for the RH and 48220-04191 for the left. I"m going to go verify that with the sticker on the springs
  11. Apr 23, 2011 at 8:58 PM
    krap22
    i found them.
    48210-04570 and 48220-04210
    and they did install the wrong ones. What a bunch of retards.
  12. Apr 23, 2011 at 9:20 PM
    carcharias
    Los Angeles, CA
    '11 AC MGM OR
    My final #'s, installed just this week, were 04571 and 04211.
  13. Apr 23, 2011 at 9:23 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    That's crazy.
  14. Apr 23, 2011 at 9:27 PM
    Bamfs01
    Bamfs01 Well-Known Member
    Magnetic Gray TRD Offroad. Locker, ATrac, DAC
    Stock leaf pack with TSB AAL, Wheelers progressive 3 leaf AAL, and Bilstein 5100's in the rear. Front OME coilovers with 885 coils. Cab mount chop. http://www.tacomaworld.com/forum/wheels-tires/37734-how-tire-rub-cab-mount-mod.html rcbs204 4x4 Illuminated Switch. http://www.tacomaworld.com/forum/lighting/68173-rcbs204-4x4-illuminated-switch.html JBL P963 6x9's and an MTX 10" sub wired inline to the stock HU with a MTX Jackhammer 404 amp. Rear diff breather relocation mod.
    Is it just me or are the springs in your first photo already preloaded/sagging? Did you have the bed loaded in that pic or something?
    Either way, they didn't do it right. I also fart in their direction lol
  15. Apr 23, 2011 at 9:35 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    My dealer did the same thing to me, they ended up shipping me the right leaf springs to my local auto shop so they could install them.
  16. Apr 24, 2011 at 5:07 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I stopped my dealer just before he was about to put in a 3 leaf pack.
