rear springs failed, no warrenty
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tim allan, Aug 7, 2011.
  1. Aug 7, 2011 at 6:32 AM
    tim allan
    tim allan [OP] Well-Known Member
    Wv
    2017 double cab trd offroad
    I bought a certified tacoma with 35980 on it , went in for the 1st oil change at a different dealer, the rear springs are failed and toyota wont replace them
    the springs themselves are frowning, will 2 " aal bring me a little above what stock should be? I want a new leafpack but don't want 2.5 inch of lift
  2. Aug 7, 2011 at 7:15 AM
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    This is a good question because I am having the same problem and do not have the money to buy a whole new leaf pack.
  3. Aug 7, 2011 at 7:18 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Mine were pretty much flat and I went with a 1.5" aal and Besteins set at 2.5" front. The truck has a slight forward rake and looks great.
  4. Aug 7, 2011 at 7:19 AM
    tim allan
    Wv
    so they went from frowning to almost flat? wondering about the difference to a all pro aal
  5. Aug 7, 2011 at 7:25 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    OP, have you looked into Supersprings or Hellwig Helper springs? I recently got the lightest duty Hellwigs for my dad for his Tacoma for birthday, they were like 60 bucks and bolt onto the springs. His truck does not have the TSB springs like mine does, and he was sagging like a bitch trying to pull trailers or with a medium weight load in the bed. Now it sits pretty level under load. They have more heavy duty helper springs as well available.
    http://www.amazon.com/Hellwig-1250-...XS26/ref=sr_1_1?ie=UTF8&qid=1312727049&sr=8-1
    Pretty cheap, but if you want to do a full leaf pack swap, All Pro makes badass 3 inch lift springs, and you can get the expedition versions which will greatly boost your bed's load carrying ability.
  6. Aug 7, 2011 at 7:25 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Can you claim the spring TSB? That replaces the whole pack.
  7. Aug 7, 2011 at 7:28 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    He's out of warranty
  8. Aug 7, 2011 at 7:37 AM
    tim allan
    Wv
    my problem is that the springs are upside down right now, rather have some arch to them for the 19' carolina skiff I plan on getting, might go with a 2" toytec aal or a 1.5" allpro progressive, whats the difference in those two springs?
  9. Aug 7, 2011 at 7:41 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    I believe the Toytec is a single extra leaf, where as the allpro employs several smaller leafs together. Multiple smaller leafs are supposed to provide a more progressive force, so that the leafs will not be as stiff until loaded, whereas the single leaf will provide the same force unloaded or loaded.
  10. Aug 7, 2011 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Being as he bought it "certified", he may have a chance at getting them replaced with the TSB leaf pack....might be worth a shot calling the 800 #
  11. Aug 7, 2011 at 7:52 AM
    tim allan
    Wv
    800 number? I have had the truck 6 months my aftermarket warrenty won't cover the springs either, original dealer says that certifys don't have to have all tsbs done
  12. Aug 7, 2011 at 7:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Toyota Customer Care number in the back of the owners manual.
  13. Aug 7, 2011 at 7:57 AM
    babytruck
    NorCal
    If it poses a danger, you would think it has to be done.
    When I got mine done, the service manager told me that the reason they do this (granted, it's not a recall) is because it's a possibility that someone could be towing something and have a load -- things would be "thrown off" if the springs weren't good. He said that someone COULD lose control of the vehicle.
    I don't tow so I really couldn't understand how it feels to drive while pulling something.
  14. Aug 7, 2011 at 8:07 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You may check to see if you have a spring shop near you. If you do see what they can do-especially if you want to keep the stock ride height.
  15. Aug 7, 2011 at 8:10 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Being you just bought the truck and it just being out of warranty, I would call Toyota North America and see if you can get anywhere that way. The truck is too new and just bearly out of warranty for them to decline the repair. Their regional rep might see it a different way than the dealer. If not it's nothing a set of dakars won't fix for about $400. Or another way you could go is to buy someones old OE leaf pack that they upgraded GL
  16. Aug 7, 2011 at 8:17 AM
    ImpulseRed008
    Susan
    SC
    very true... worth a shot
  17. Aug 7, 2011 at 8:37 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Chris4x4 has a point... never take no from someone who can't tell you yes.
    Frank
  18. Aug 7, 2011 at 9:02 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    So let see,
    1. you bought a certified truck just before original oem warranty expired, plus got an aftermarket extended warranty.
    2. Now 6 months later you take it in for oil change & non-selling dealer says rear springs are shot.
    3. No customer complaint during original warranty for TSB and neither your selling dealership or the one saying the springs are bad say you qualify for warranty replacement? Why doesn't the extended warranty cover it, not even considering the TSB, is it considered a wear and tear part or on the exclusion list?
    I definitely would call the 1-800 number for sure & ask calmly how this can happen. How miles out of oem warranty are you? G/L with either upgrade or getting resolution through 1-800 Toyota.
  19. Aug 7, 2011 at 10:12 AM
    tim allan
    Wv
    im at 41k
  20. Aug 7, 2011 at 10:27 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Sounds like you've been had.
    The original owner probably noticed this problem, went to get the dealer to put the TSB leaf pack on, got denied, and decided to sell the truck just before the warranty expired to get the best bang for his buck.
