REAR: Springs ~VS~ Shocks
Discussion in 'Suspension' started by Nonfatwater7, Nov 13, 2011.
  1. Nov 15, 2011 at 6:40 AM
    acdronin
    acdronin Well-Known Member
    I would echo some of the guys on here for ditching the blocks and going with the aal's and 5100's the rear is much smoother and absorbs bumps better than the front. Not too much $$ and wow, what an improvement!
  2. Nov 15, 2011 at 8:32 AM
    Nonfatwater7
    Nonfatwater7 [OP] Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    Yeah I am really pushing for the 5100's and I'm also ordering wheel spacers right now too so after all that I will deal with the blocks...
    As much as they suck, for some reason I like the simple idea of throwing a huge chunk of metal in and resulting in a nice lift lol.
  3. Nov 15, 2011 at 8:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Well... using your words, an AAL IS a huge chuck of metal that results in a nice lift :D
  4. Nov 15, 2011 at 9:15 AM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    ...damn
    yeah ok but it is shaped and flexes and what not. A block is a block man!!!! There is no denying it!
  5. Nov 15, 2011 at 9:19 AM
    Pugga
    Massachusetts
    I know what you meant, just trying to steer you in the right direction and use your own words to do so :D
  6. Nov 15, 2011 at 9:22 AM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    Ehhhhh....idk man
    I'm not into that. If body lifts were the way to go then I think you would see robby gordan and the baja boys running them....as well as other pro froaders.
    I'll pass on the body lifts
  7. Nov 15, 2011 at 9:32 AM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    true...but there is a lot of evidence against body lifts and I have heard great things about well made wheel spacers. As far as blocks go, hey, mine has done everything I wanted it to so I can't complain. Its an easy solution to a suspension lift. The axle wrap doesn't bother me much but I will probably look at an AAL here soon for multiple reasons...
