Rear springs with no lift
Discussion in 'Suspension' started by tacoontherock, Nov 14, 2009.
  1. Nov 14, 2009 at 5:09 PM
    tacoontherock
    tacoontherock [OP] Well-Known Member
    Hawaii
    09 TRD offroad
    Camburg Coilovers,billy 5100 in rear, Blacked out emblems,Satoshi color matched grill, Flowmaster 50, Allpro Apex front and rear bumpers.
    Does anybody make a rear spring that performs like Deavers but does not add any lift. Cant seem to find any. Do i have to have them custom made? I like the way my truck sits now and dont want to lift the rear. Thanx
  2. Nov 14, 2009 at 11:45 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Can't Deaver custom make OEM style ones? I'm sure Alcan can make them for you.
  3. Nov 14, 2009 at 11:58 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Why are you considering a new rear leaf pack? What is your goal/desired outcome? Other then having it sit the same as before.
    My guess is that you want a better performing rear leaf that isn't so soft, correct?
    Anyway, if you get a stiffer set of leafs that will sit higher as it would 'sag' less then the soft ones you have now.
    You could try an add-a-leaf. That would also raise the back a bit.
    My suggestion is you get a Dakar/OME or Deaver leaf pack and take out some of the leafs until it's close to what you're looking for.. and then get yourself a couple of sandbags and toss them in the back to attain more or less the same posture as before. Or add a shell/cap?
    Basically a vehicle suspension system is just that, a system. And changing/upgrading one component will have an effect on that system - guaranteed.
    Well, I am no expert on this issue certainly. Did a lot of extensive research on suspension when I upgraded mine earlier this year.
  4. Nov 15, 2009 at 12:30 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    deaver and alcan can do custom leafs, 0" lift to whatever, i have 2" lift deaver 10 pack. i should have gone for more but ohwell. just call them and tell them what you want
