Rear squeaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Guamtaco6, Jul 2, 2017.
  1. Jul 2, 2017 at 3:19 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
  2. Jul 2, 2017 at 3:25 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Just turn up the radio and you'll be fine. It's a truck. Get over it.
    SLO/TACO likes this.
  3. Jul 2, 2017 at 6:13 PM
    Guamtaco6
    Guamtaco6 [OP] Well-Known Member
    2017 Black Tacoma TRD OR DCSB
    Appreciate the derailing of the topic due to feelings. Would jacking up the body to loosen up space between the pucks and leafs actually work so I can get water sprayed into there. As it seems that there's crud around it?
  4. Jul 2, 2017 at 6:42 PM
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Wd40 doesn't last long for me. PB blastr works a bit longer and is my go to due to price.
    T9 boeshield has worked the best and lasted the longest, but around here is twice the price of PB.
    None of these last forever... At most a couple weeks... But i also live off road.
  5. Jul 2, 2017 at 6:55 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    It couldn't hurt to try your luck at a dealership. Quite a few guys have had their rear leafs replaced because of this issue. Hopefully you have a good dealership (like I said before, some will tell you it's normal and to pound sand).
    I'd try the dealership before throwing grease or anything on it. Adding grease isn't recommended by Toyota, so if you add lube and *then* take it in, you are more likely to get told to pound sand.
  6. Jul 2, 2017 at 6:56 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
  7. Jul 2, 2017 at 7:02 PM
    AAChaoshand
    AAChaoshand Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Not acceptable, get them replaced, I did under warranty and had no issues getting the service department to do their job. I was told last year that the engineers knew there was a problem with them but there was no ETA on a TSB or fix other than replacing them and hoping for the best. I have put 20000 miles on my new ones after I had the original ones replaced around 5000 miles and zero issues.
  8. Jul 2, 2017 at 7:03 PM
    Tacomabud17
    Tacomabud17 Active Member
    Josh
    This post made me laugh. Turn up the radio and get over it.
  9. Jul 2, 2017 at 7:13 PM
    Gettin Lost
    Florida
    2021 TRDOR
    I complained about my squeeky leafs 3 times at the dealership and all 3 Times they said all they could do is grease them. I was told if i keep complaining i could possibly get them replaced... But it would be with the same type of leafs and likely to happen again. They use white lith grease on the leafs at the dealership where i get my truck serviced.
    I had a 2016 4cyl 2wd SR... And a 2016 sr5 3.5 V6 2wd... and now a 2017 sr5 4x4 v6... ALL 3 HAD SQUEAKY LEAFS.
  10. Jul 2, 2017 at 7:17 PM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    1988 Hilux here. 29 years old and no squeaking. Still with the stock leafs.
  11. Jul 2, 2017 at 7:28 PM
    AAChaoshand
    Brandon
    Central Texas
    File a complaint with Toyota, they will replace them. I got the same OEM ones back on but since they were a later build I haven't had any issues.
  12. Jul 2, 2017 at 7:36 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    You should post this on a hilux board.
  13. Jul 2, 2017 at 7:40 PM
    tacoflavoredkisses1
    Well that's the heritage I bought in to when I picked up my 2016. Time will tell, but I hope that in 2047 my truck is around and kicking. I just hope I get there without having to replace all of the key components along the way.
    Friggin Fuego[QUOTED] likes this.
  14. Jul 2, 2017 at 8:01 PM
    Friggin Fuego
    I tried looking for a LN65 Hilux board unsuccesfully. Not many of us left.
  15. Jul 2, 2017 at 8:09 PM
    #35
    Lt. Dangle
    Ohio
    Haha, I imagine not.
  16. Jul 2, 2017 at 8:13 PM
    #36
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Mine squeeks nasty . I pressure wash the bushings to clean them out. I tried wd40 and silicon spray and both only last maybe a week before it comes back. I started using lithium spray and it holds way longer
  17. Jul 2, 2017 at 9:38 PM
    #37
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I used to just spray mine down with some liquid silicone, and that helped a bit. But I've recently started pressure washing the springs during each car wash (and especially after I've been off road). That has helped tremendously. Then I'll spray the clean bushings down with the liquid silicone. It seems the tiniest bit of dirt makes these springs sound like an old rocking chair.
  18. Jul 2, 2017 at 10:05 PM
    #38
    Gettin Lost
    Florida
    2021 TRDOR
    Meh... My cousins 2014 squeaks. My first third gen taco had a build date of December 2015. This new one has a build date of march 2017. Still squeaky...
    Did they come out with a completely new leaf spring setup??? If not, its not worth leaving my truck for even a few hours.
    Flowmaster 40 series exhaust and an S&B cai... I dont hear the squeaks anymore :D
  19. Jul 2, 2017 at 10:08 PM
    #39
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    this sounds incredibly dumb but check and make sure your spare tire hoist chain is cranked all the way up
    i chased a non-existent leaf squeak for the first 6 months i owned my '12 and it was 100% the spare tire
  20. Jul 3, 2017 at 8:00 AM
    #40
    Brokinarrow
    Brokinarrow Well-Known Member
    Brian
    Garner, NC
    2017 Tacoma TRD Offroad
    Thangs and stuff
    Mine does this as well and i just ignore it lol.
