Rear Stabilizer Bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taoist, Mar 22, 2018.
  1. Mar 22, 2018 at 7:35 AM
    taoist
    taoist [OP] taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
  2. Mar 22, 2018 at 7:37 AM
    phsycle
    phsycle Well-Known Member
    CA
    I'm not following. What's your point?
  3. Mar 22, 2018 at 7:41 AM
    RikMart
    RikMart Well-Known Member
    Rhode Island
    2017 Tacoma TRD Off-Road
    -TRD Pro Grille -Husky Xact contour mats -2nd Gen Runner-board -LED interior Lights -Denim Cotton Seat covers -CaliRaised 30in LED Bar -KC Led Fogs -XenonDepot 5000k HID
    I'm guessing he wants confirmation that 2018 tacomas come with rear sway bar.
  4. Mar 22, 2018 at 7:42 AM
    taoist
    taoist [OP] taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Indeed Toyota does not make or provide a rear sway bar on any Tacos.
  5. Mar 22, 2018 at 7:47 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    OP has a good eye dam. I browsed through it and that spec idnt jump out at me...
    :pccoffee:
  6. Mar 22, 2018 at 7:48 AM
    stealthmode
    Alberta
    There are aftermarket generic ones available if your looking for one. I think summit racing carries them of the top of my head
  7. Mar 22, 2018 at 7:50 AM
    phsycle
    CA
    I'm still not getting it. All 3rd gens came with front and rear sway bars. And if I remember right, so did all 2nd gens. What's so special about this?
  8. Mar 22, 2018 at 7:53 AM
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    Interesting. The rear is pretty stable without one, so not sure why they wanted to add it.
    I've seen them on some (not many) tundras for years now.
  9. Mar 22, 2018 at 7:54 AM
    taoist
    taoist [OP] taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Please provide Toyota part number of rear sway bar for Gen 3 Taco.
  10. Mar 22, 2018 at 7:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. Just a front sway bar. The is nothing but leaves and shocks out back.
    A rear sway bar in a light pickup would would get it either very neutral or tend toward oversteer? The tail is already pretty happy in the wet and a lot of fun in the snow.
    I think there is an advantage if you are towing heavy loads (prevents trailer sway?), but I don't know for sure.
  11. Mar 22, 2018 at 7:55 AM
    taoist
    taoist [OP] taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Slide in camper, dry weight 1300 lbs.
    Ilmjetfuel, tonered and Ras61[QUOTED] like this.
  12. Mar 22, 2018 at 7:56 AM
    Ras61
    Arlington VA
    Good point...
  13. Mar 22, 2018 at 7:56 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    I don't think the SR5s did. I didn't see a sway when I installed my SUMOs. I definitely have the front sway, though.
  14. Mar 22, 2018 at 7:56 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Tacoma's don't have rear sway bars.
    They have stability bars which is the bar that hinges between the axel and the frame.
    The picture below shows a stabalizer bar on top and a sway bar at the bottom. Tacomas only have the top bar.
    Note:the picture below is NOT a Tacoma.
    stealthmode, RikMart and rlx02 like this.
  15. Mar 22, 2018 at 7:57 AM
    phsycle
    CA
    According to the brochures, all trims came with front and rear stab bars for '16 and '17?
    https://www.toyota.com/content/ebrochure/2016/tacoma_ebrochure.pdf
  16. Mar 22, 2018 at 8:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not on my Taco. That looks like a Ford with airbags in place of factory coil springs?
    na8rboy likes this.
  17. Mar 22, 2018 at 8:02 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I see. Toyota calls both stabalizer bars...
    The rear bar doesn't allow the axel to sway left or right (x-axis).
    I agree. The brochure is a bit misleading but there is something there to stabalize the suspension.
    phsycle[QUOTED] likes this.
  18. Mar 22, 2018 at 8:02 AM
    Dirty Harry
    Andrew
    SW Florida
    Alright, who's crawling under to take pictures on lunch-break?
  19. Mar 22, 2018 at 8:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  20. Mar 22, 2018 at 8:04 AM
    phsycle
    CA
    I've always equated stabilizer bar with sway bar, but you are right--I don't remember seeing one down there. Either way, I don't see what the OP was getting at, since whatever Toyota was referring to has been on 2nd and 3rd gen trucks.
    tonered[QUOTED] and James_Bond like this.
