REAR SUA GUYS (dcsb) need some drive shaft advice
Discussion in 'Long Travel Suspension' started by Rylee, Aug 31, 2013.
  1. Aug 31, 2013 at 9:35 AM
    Rylee
    Rylee [OP] Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    i have an 07 2wd dcsb and bought the DMZ spring under kit. ive heard multiple ideas and opinions of what to do with adding a slip yoke, and shortening, but what are you running for a CB?
    any suggestions are helpful thanks.
  2. Aug 31, 2013 at 9:38 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    You can run a one-piece Tom Wood driveshaft with double-cardan joint and slip yoke. No need for a carrier bearing.
  3. Aug 31, 2013 at 9:48 AM
    Rylee
    Rylee
    Mission Viejo
    07 dcsb long travel
    any idea on dimmensions for that? any drawbacks of a 1pc?
  4. Aug 31, 2013 at 9:55 AM
    KenLyns
    Belly of the Beast
    It's recommended you measure the flange-to-flange lengths after the SUA kit is installed. Measure at ride height, full droop and (ideally) full compression, then order the driveshaft.
  5. Aug 31, 2013 at 10:13 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Lower clearance on the drive shaft, but that shouldn't be a factor for a 2WD. Applies more to rock crawling.
  6. Sep 1, 2013 at 11:18 AM
    Rylee
    Rylee
    Mission Viejo
    07 dcsb long travel
    anyone know a rough estimate of how much a tom woods one piece would cost?
  7. Sep 5, 2013 at 4:46 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    I talked to tom woods and they don't make them anymore. If I were you, Id use the stock CB because its a lot quitter and will work fine. If you want a good shop to do your slip yoke, I know a guy that will do it for $250 if you bring the driveshaft to him.
  8. Sep 5, 2013 at 5:51 PM
    Rylee
    Rylee
    Mission Viejo
    07 dcsb long travel
    thanks hiatt, im getting a slip yoke and new tacoma cb added when the truck goes to LSK
