Rear suspension 2013 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cpt Sciatica, Apr 17, 2025.
  1. Apr 17, 2025 at 9:12 PM
    Cpt Sciatica
    Cpt Sciatica [OP] New Member
    Ali
    2013 TRD Off Road
    Hello world,
    I have a 2013 trd off road tacoma 2.7, manual. Rear suspension needs repair.
    My leafs are cracked through like a cm space and I'm sagging. I want to get new leafs but not sure what I need. Should I order from toyota or can I get an oem part that won't be a down grade?
    I also switched out my rear shocks for bilstein B6 4600. Was that a good move or not?
    Any advice is welcome.
  2. Apr 19, 2025 at 8:44 AM
    Flex-AZ
    Flex-AZ Well-Known Member
    Flagstaff, AZ
    2015 TRD Sport DCLB
    Camburg/Deaver mid travel
    You can find OEM takeoffs here pretty commonly. That will be the easiest and likely cheapest way to go. Otherwise most aftermarket leaf packs will give a lift. I believe Deaver makes a non lift leaf pack but it has a much lower load range and is made more for suspension articulation than load carrying.
  3. Apr 19, 2025 at 9:19 AM
    545 Well-Known Member
    2015 Access Cab
    You sure you have a trd offroad? I could be wrong but I don’t believe trd offroad was available with a 2.7
    Is yours a 4x4 or a 2wd 5 lug truck? If it’s 4x4 I think they are all the same and you can even use the 3rd gen rear springs
    There was also a recall, so you might even be able to get them for free unless it’s been done. How many leafs including the overload are in your leaf spring packs now?
