Rear suspension advice!
Discussion in 'Suspension' started by ctheulen, Apr 9, 2022.
  1. Apr 9, 2022 at 5:37 PM
    ctheulen
    ctheulen [OP] Alaskan Assassin
    Glenwood Springs, CO
    2005 Tacoma SR5 4x4 DCLB
    3 inch lift Toytec Ultimate Coilovers Deaver Stage 3 leaf pack Camper shell w/ Prinsu Rack and RTT Maxxis Razr MT 285/75/16
    I'm in the process of ordering a new suspension for my 2nd gen. I'm currently running Deaver Expedition Series Rear Springs, Stage 3. Wondering if I could run these for additional droop: https://www.bilsteinlifts.com/shop/...rear-lift-shocks-2005-2022-toyota-tacoma-4wd/
    Only considering it because the vendor is out of the 2-3 inch lift shocks.
    Or would I be causing damage to the 3.5-5 inch shocks?
    Thanks for any advice!
  2. Apr 11, 2022 at 3:34 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Compare compressed length. Most likely you will need to reduce up travel with extending bump stop and ride will become very poor with constant bottom outs. The whole point of all expedition leaf packs is to just increase load capacity. It is a road many have gone down to just end up going spring under set up much like this 2005+ Toyota Tacoma Rear Spring Under Kit – JD Fabrication
  3. Apr 11, 2022 at 3:46 PM
    ctheulen
    Thanks! Measured everything over the weekend. I instead ordered the rears from another vendor.
    I purchased the Deavers for that exact reason. Travel across country with a lot of video production gear. And constantly have around 500 pounds in the rear, daily. Great pack for my needs.
