Rear Suspension - Best Ride Quality
Discussion in 'Suspension' started by TacoMaxxxx, Feb 16, 2017.
  1. Feb 16, 2017 at 8:05 AM
    TacoMaxxxx
    TacoMaxxxx [OP] Well-Known Member
    Orange County, CA
    2016 Limited
    I'm currently running MaxTrac 4" Spindles in the front and want to level out the rear. I have a SnugTop on order so I'm looking for something that will take me to about 2" to level out the stance. I need something that can handle a shell but I'm very worried about the reports of the Dakars squeeking. I'm not worried about the money, just the ride quality. Suggestions?
  2. Feb 16, 2017 at 9:03 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    Deaver J66 springs and have it custom arched a little bit more to accompany the Snug Top.
    The J66 by itself will have 1" of lift.
    Pair with the shock of your choice ( I can get you King ) and you are good to go!
    JT
    ItsRichieRich and Justinlhc like this.
  3. Feb 16, 2017 at 10:49 AM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    So I went over to Deaver and spoke with Scott. Upon showing him my truck, he suggested a 2"-2.5" setup that they are going to install on Monday. I'm confident that he will make any adjustments once I get my cap. I'm very glad I live so close to them.
  4. Feb 16, 2017 at 6:21 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I don't have a cap or any weight, but my J66's ride like a dream. I'm very happy with the way they ride compared to the 3-leaf progressive I had before.
  5. Feb 16, 2017 at 6:23 PM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Yeah, they couldn't have been more helpful. They are installing the U402 which has a bit higher load rating. Anything will be better than the block I have now.
  6. Feb 17, 2017 at 3:29 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I have the Dakars and they are fantastic. I don't know why some complain about squeaking with the Dakars. I have 27000 miles on them now and no squeaks.
    Kyitty likes this.
  7. Feb 17, 2017 at 6:22 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    You are fortunate to have them close by! I'm curious to hear what you think of them when installed.
  8. Feb 17, 2017 at 10:17 AM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Turns out I'm being told my Bilstein 5100's won't work with a 2.5" lift in the rear. I'm now looking at changing my rears to something quite a bit more expensive to handle the larger lift. We'll see how this goes...
  9. Feb 17, 2017 at 12:24 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    ADS
  10. Feb 20, 2017 at 10:18 AM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Just got back from Deaver. I had the U402's installed and it looks awesome. Best customer service. Highly recommended.
    desertrunner24 likes this.
  11. Feb 20, 2017 at 1:56 PM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    And the ride/performance?
  12. Feb 20, 2017 at 2:16 PM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Great as far as I can tell. A bit stiffer than stock but that is to be expected. I'll have final thoughts when I get my Icon Resis and Coilover setup on Wednesday.
  13. Feb 21, 2017 at 1:53 PM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    By the way, it only ended up giving about 2" of lift on my 2016 DCSB and factory tonneau cover. The lift is stated as 2.5" - 3". I don't mind so much as that sits my truck at almost perfect level (4/2). I just hope it doesn't "settle" any more.
  14. Feb 23, 2017 at 5:50 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Just talked to scott about the u402 springs while Passing through LA. Just wondering if you have any hub to fender #s by chance?
    I have an access cab and fox coilover didn't give me as much lift as i had assumed/ hoped for. Concerned it might give me a tad too much lift. I do have a shell and constant weight though. Any measurements or info would be appreciated if you happen to have them on hand
  15. Feb 23, 2017 at 5:56 PM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    I am measuring 24" from the center of the hub to fender. I got almost exactly 2" of lift. I would say you'd get a good 1/4-1/2" over me since you are running an access cab. My tonneau weighs 80LBS so it's not exactly light. What kind of lift do you have up front?
  16. Feb 23, 2017 at 6:00 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    All pro expo pack
  17. Feb 23, 2017 at 6:26 PM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Sure thing bud.
  18. Feb 23, 2017 at 6:30 PM
    BAMFTACO
    Juan
    Kings bruh
    if your running front spindles the expo will even you out and can carry heavy load aswell
  19. Feb 23, 2017 at 6:32 PM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    If you are answering my initial post then I've already had Deaver U402's installed. Thanks. I was confused as to what you were referring to.
  20. Feb 23, 2017 at 6:41 PM
    BAMFTACO
    Juan
    Kings bruh
    My bad man didn't read that post
