Rear Suspension Binding? w/ Video
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtrue, Jul 16, 2017.
  1. Jul 16, 2017 at 6:21 PM
    jtrue
    jtrue [OP] Well-Known Member
    SLC, UT
    2014 Super White Tacoma TRD
    Buddy just happened to be filming and caught my rear binding and then releasing while I was flexing, or at least that's what it looks like. Any ideas on root cause? Dakars with Icon 2.0 shocks in the rear.
    https://vimeo.com/225784553
  2. Jul 16, 2017 at 8:03 PM
    Pigpen
    Dan
    Northwest Montana
    I would guess it's the shackle. The stock inverted shackle probably got stuck for a moment being pulled at full flex like that.
    jtrue[OP] likes this.
  3. Jul 16, 2017 at 8:46 PM
    brapp_kid7
    brapp_kid7 Well-Known Member
    Following.
    That's the extreme flex.
  4. Jul 16, 2017 at 9:53 PM
    jtrue
    SLC, UT
    Thanks, seems like the mechanism to cause the shackle to bind. I'll just keep an eye on it and check torque of those bolts.
  5. Jul 17, 2017 at 10:03 AM
    WillyJam
    WillyJam Well-Known Member
    My friend's truck had the same problem. He replaced his stock Shackle with After market ones. problem solved
  6. Jul 17, 2017 at 10:32 AM
    jtrue
    SLC, UT
    Who makes and aftermarket shackle for.our trucks? Don't really want to go with a full flip kit.
  7. Jul 17, 2017 at 1:01 PM
    Wasatch
    Wasatch Well-Known Member
  8. Jul 17, 2017 at 6:30 PM
    jtrue
    SLC, UT
  9. Jul 17, 2017 at 7:06 PM
    Wasatch
    Yes sir!
