Rear suspension bottoming out!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boeingoing, Jan 5, 2013.
  1. Jan 5, 2013 at 5:39 PM
    Boeingoing
    Boeingoing [OP] Member
    Victoria, BC Canada
    2010 Tacoma sr-5
    I have a 2010 double cab SR5... seems the rear suspension bottoms out with minimal weight in the back, I even noticed it on a trail the other day with 3 guys in the truck and 200lbs in the back when we hit a rut. I realize this is a mid size truck... but shouldn't it be a bit more solid than that? My questions are does the trd have better rear suspension and is there a mod I can do to beef up the leaf springs or something? The truck isn't bagged on either, it only has 13,000k....:confused:
  2. Jan 5, 2013 at 5:51 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    There might be a tsb for rear leaf springs on the 10 double cab (the stronger leafs might have been put in automatically in Canada, but not completely sure).
    Payload on my 11 regular cab is 1435 lbs. If the three guys weighed 200 you would only be at 800.
  3. Jan 5, 2013 at 5:58 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    The TRD package comes with upgraded blistien shocks and beefier springs...
  4. Jan 5, 2013 at 6:02 PM
    Boeingoing
    Victoria, BC Canada
    2010 Tacoma sr-5
    It's a US truck... When I had the truck in for service I asked them if there was any outstanding TSB's and they said no... I guess I should do some research...
  5. Jan 5, 2013 at 6:05 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    False. Springs are the same, just the yellow bilstein shock vs the black Tokico shocks.
  6. Jan 5, 2013 at 6:07 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    Here is my suggestion, from experience. If you are going to use it like a real truck, and not a grocerey getter, spend the money and change out the rear leafs to an aftermarket set . I would highly suggest a set of Expo's . I started with a toytec add a leaf,and shattered both of them. Then went to a middle of the road replacement spring pack, and with any type of real weight they settled back to exactly zero lift and not much better ride than stock. Finally broke down and got the Expo's installed,now with a loaded truck it still has 2 + inches lift over stock, never bottoms out, and rides excellent on the road. I have a set of 5100's in the back, and they ride good, but at some point I am going to swap them out for the Bilsteins meant to handle the additional lift. Just a suggestion from someone that learned the hard (expensive ) way.
  7. Jan 5, 2013 at 6:17 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I thought the trd package came with progressive rate springs?
  8. Jan 5, 2013 at 6:25 PM
    The Traveler
    SoCal
    In the front, yes.
  9. Jan 5, 2013 at 6:28 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    In the front coils, yes...in the rear they are all the same springs, either the standard 3 leaf or tsb 4 leaf. The tsb is Toyota's fix for the problem the op describes. Canadian trucks get the 4 leaf pack standard
    Edit: traveler beat me to it...stupid small keys on my phone.
  10. Jan 5, 2013 at 6:29 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    and the front springs are better arnt they?
  11. Jan 5, 2013 at 6:33 PM
    jmg256
    Al Tonter
    TRD Offroad
    What is better than 'stock'? The TRD offroad coils are stock to TRD offroad trucks...the linear rate springs are 'stock' to sports and sr5
  12. Jan 5, 2013 at 6:33 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    Make: Chevy Model: Pile
    Yes
    Get the TSB springs. Not great, but better, and the way the truck should have left the factory.
  13. Jan 5, 2013 at 6:34 PM
    jmg256
    Al Tonter
    TRD Offroad
    'better' is a relative term in your usage of the word...
  14. Jan 5, 2013 at 6:36 PM
    The Traveler
    SoCal
    I just did the Toytec 2" AAL for non TSB leafs. Love the lift and and I rarely ever bottom out. Only when wheelin' hard
  15. Jan 5, 2013 at 6:37 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    . . . :popcorn:
  16. Jan 5, 2013 at 6:41 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    i would recommend plasti-dipping them black, as long as bedsides are left white
  17. Jan 5, 2013 at 6:43 PM
    The Traveler
    SoCal
    :thumbsup:
    Don't forget all the sand on the carpet.
  18. Jan 5, 2013 at 6:50 PM
    The Traveler
    SoCal
    Don't screw up the truck though...you'll be needing to sell the LT kit in 6 months to pay rent. :rolleyes:
  19. Jan 5, 2013 at 7:22 PM
    Boeingoing
    Victoria, BC Canada
    2010 Tacoma sr-5
    Thanks for the reply's.. so my options are to go to toyota and get the 4 leaf TSB or spend the cash for an aftermarket set to fix it right? Wish I could get the lift... but need it to fit in my garage!
  20. Jan 5, 2013 at 7:26 PM
    Boeingoing
    Victoria, BC Canada
    2010 Tacoma sr-5
    sure enough.. just checked and only 3 leafs. Shouldn't the dealer have pointed this out when I asked him if there were any TSB's outstanding on the truck?:mad:
