Rear suspension leveling question
Discussion in '1st Gen. Tacomas (1995-2004)' started by SargeSlapnuts, Jan 18, 2012.
  1. Jan 18, 2012 at 8:24 AM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    well my rear end now sit an 1 1/2" lower than the front if measured from the top of the tire to the bottom edge of my fender flares. i was wondering who make an 1.5" shackle lift kit that i can buy.
    Or is this just because the front fender flares sit higher on the body of the truck?
  2. Jan 18, 2012 at 8:28 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have a 1.5'' Toyotech shackle kit. No problem here. Why not just get an AAL tho?
  3. Jan 18, 2012 at 8:40 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    i already have an aal in the rear. since i lifted with the ome 883's the front of the truck appears to sit slightly higher. i measure the height to the bottom of the fender flares from the ground and got 38.25" exactly all the way around. then i measured from the top of the wheel to the bottom of the fender flares on all four side and came up with the following:
    front: both at 9.75" from top of tire to bottom of flare
    rear: both at 8.25" from top of tire to bottom of flare
    you can see in my sig it looks like the truck is lower in the rear. . .
    unless im going insane :goingcrazy::goingcrazy::goingcrazy:
  4. Jan 18, 2012 at 8:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah, well how many miles are on the AAL and leafs?
    So yea, just get some shackles.
  5. Jan 18, 2012 at 9:00 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    the aal's prolly about 25k-30k the leafs are original to the truck although they look fairly healthy with the aal's installed. prolly with just go with the shackle lift
