Rear suspension lift 09 Base 4x4
Discussion in 'Suspension' started by Byrdie, Dec 21, 2023.
  1. Dec 21, 2023 at 8:21 AM
    Byrdie
    Byrdie [OP] New Member
    2009 Tacoma Base access cab 4x4
    If i add a 2" block under my leafs or do a AAL to my rear can i still use the factory shock.
  2. Dec 21, 2023 at 8:51 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World.
    Can you still use it? Technically yes, but it is going to act like a limit strap and probably die a quick death.
    Is it a good idea? No, absolutely not. You should get appropriate length shocks to fit.
    This is one of those cases where saving a few pennies short term is going to cost you more in the long run. Do it right the first time.
    memario1214 likes this.
  3. Dec 22, 2023 at 8:28 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    I recently added a 1” block to the rear and wanted to go back to standard travel shocks, so i made 3/16” lower brackets that raise the lower mount point up 1”. Therefore no need for extended length shocks. This may not work as well with aal.
