Rear Suspension Overload Upgrade?
Discussion in '1st Gen. Tacomas (1995-2004)' started by btu44, Mar 26, 2017.
  1. Mar 26, 2017 at 4:27 PM
    btu44
    btu44 [OP] Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Here's a picture of my Tacoma with max off road camp load.
    10 gals of gas, 12 gal water, the ammo can has heavy recovery gear, hi-lift, heavy ENGEL cooler, full camp kitchen, etc. The weight really added up.
    I have OME Dakars in the rear. With this load the main leafs are solid into the 1st overload leaf. Probably only have 3 or 4 inches of travel left. My last trip to Jawbone went fairly well. In the slow speed technical trails like in the picture, the load helped with traction and articulation. But on the faster desert floor dirt roads bottoming was difficult to avoid. Coming over the back side of the dirt humps for redirecting water is usually good for a hard bottoming even going slow. This is the issue I would like to improve
    If this load was a regular occurrence I would simply put on OME AAL and revalve the shocks for the new spring rate and all would good. But this load only happens about once a year.
    Usually I'm off roading with an empty bed and small cooler. With no load the rear leaf are a little stiff and articulation is not so good. Teeter tottering on 2 wheels is not uncommon.
    So an AAL is my last choice. Here a few other ideas.
    Most everybody says airbags. I'm not much for them because I don't think there quality is up to 4WD standards.
    A hydraulic/air bump stop from ICON or FOX. When I do some eyeballing under there to see if the bump stops would fit it looks really tight. Anybody see hydraulic/air bump stop on a 1st gen? Pictures would be great.
    My favorite idea is ICOM 2.5 shocks with remote reservoirs and compression dampening adjusters. The ICOM 2.5s have 20% more compression at the end of there travel and with there adjusters maybe just the fix. The 2 biggest obstacles are an ICOM custom build and relocating the shock inward about an inch. Big PITA. Maybe over my fab skills. Haven't seen a kit that did not sacrifice the spare tire.
    So I'm open to any ideas especially if someone is already using the idea.
    Thanks
  2. Mar 26, 2017 at 4:51 PM
    ZUK
    ZUK Gearinstalls.com
    Ken
    Chandler AZ
    2001 white Taco TRD 3.4L auto (SAS FJ60 flip) 35" KO2 5" AllPro leafpacks front and rear,
    SAS,1985 FJ60 flipped axle, 35" KO2,5" AllPro leafpacks front and rear,
    DustStorm4x4 and 2BeersPlease like this.
  3. Mar 26, 2017 at 5:29 PM
    2BeersPlease
    2BeersPlease Well-Known Member
  4. Mar 26, 2017 at 5:35 PM
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
  5. Mar 26, 2017 at 7:05 PM
    btu44
    Long Beach area, Ca
    I really like this solution. Fairly easy fabrication, plenty of room in that area, little effect on articulation and keeps the spare.
    You also changed my mind about an air bag. If I can find one with 10" of extension this would be an excellent setup.
    Cheers, thank much. :thumbsup:
  6. Mar 26, 2017 at 7:09 PM
    btu44
    Long Beach area, Ca
    mrlee[QUOTED] likes this.
  7. Mar 26, 2017 at 7:19 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
