rear suspension question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redtacoma, Sep 26, 2010.
  1. Sep 26, 2010 at 10:04 PM
    redtacoma
    redtacoma [OP] Member
    san diego
    06 tacoma crew cab
    will the rear lift blocks on a 4wd tacoma fit on the rear of a 2wd tacoma is there any difference?
  2. Sep 26, 2010 at 10:07 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    if the 2wd is a 6lugger/ prerunner.
  3. Sep 26, 2010 at 10:26 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    ^ What he said. If it is a prerunner, then yup.
  4. Sep 26, 2010 at 10:43 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    I'm assuming because your truck info says double cab you have a pre-runner then yes lift block will work. Most people will call you names for even thinking about blocks, I don't like them personally but i don't know your circumstances/needs. Lift block go between the leaf springs and the axel. spring over axel format will lift, spring under axel will drop. 5 luggers are spring under, pre-runner/4x4 are spring over
