Rear Suspension Question...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteelerJim, Sep 26, 2019.
  1. Sep 26, 2019 at 2:24 PM
    SteelerJim
    SteelerJim [OP] Well-Known Member
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    ARE Overland Topper, WeatherTech Mudflaps
    I have a '19 TRD OffRoad Long Bed. I have purchased a Leer Topper for it AND in a few weeks the wife and I are planning a camping trip thru the Smokies. So it will have the weight of the topper(probably 150# or so) and the weight of our gear. With tent, coolers and such I am guessing 300-500# or so.
    I know if I lower my tailgate and sit on it that it will squat at least an inch. I weigh 275. I realize that my weight is all on the very rear when I sit on the tailgate, but I'm guessing the shell and gear will squat it atleast 1.5" or so.
    My question...What is the best route to keep it level with the load I plan on having? I do not want oncoming cars constantly flashing their lights at me and I don't want a nose high look when loaded. If your solution lifts the rear an inch or so I have no problem with that as I plan to put the 1/2" spacer from @HeadStrong Off-Road on it, too. So the front will be lifted about an inch. I'm thinking add-a-leaf but not sure. And if that's the answer, are they hard to install? All help is appreciated...
    HeadStrong Off-Road likes this.
  2. Sep 26, 2019 at 3:10 PM
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Lots of planning going into this Smokies trip, lol
  3. Sep 26, 2019 at 3:17 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    Sorry that bugs ya...
    Alnmike likes this.
  4. Sep 26, 2019 at 3:19 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    I get such a kick out of people that stop to make a sarcastic comment, but offer no real info regarding the post...
    Trucknorris, pwmullen3 and Junkhead like this.
  5. Sep 26, 2019 at 3:22 PM
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    You should sit level with the weight you have now if you dont add a spacer in front.
    If you really have to do the front spacer, you can go blocks or add-a-leafs in the rear. If youre looking at easy to install Id recommend a Roadmaster RAS or Sumosprings
    SteelerJim[OP] likes this.
  6. Sep 26, 2019 at 3:46 PM
    Yann
    Mick
    South Carolina
    Not sarcastic at all, I was on the campsite thread too.
    Also, a comment bumps your post up to the top of the list again.
  7. Sep 26, 2019 at 3:48 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Smokie mountains, beautiful area, lots of great scenery. Enjoy your time. Put all your gear in there and forget about it. You will be fine.
  8. Sep 26, 2019 at 3:50 PM
    doorsidedown
    doorsidedown Well-Known Member
    Hey Jim, I’d throw a progressive AAL on there from @HeadStrong Off-Road. Easy install, lasts a long time.
    Another option is to contact someone like Deaver or General Spring and have them make you a full replacement, but based exactly on what you need.
    Or... airbags.
  9. Sep 26, 2019 at 4:13 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    OK. My bad...No biggie. And yes, my wife is one of those that has to have an itinerary. So lots of planning, lol.I'm the opposite.
    Yann[QUOTED] likes this.
  10. Sep 26, 2019 at 4:17 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    Thanks for the advice.
  11. Sep 26, 2019 at 4:23 PM
    su.b.rat
    su.b.rat broken truck
    or Sumo springs. not sure you are looking to band aid or short cut needs, but about 200$ and an hour install just may totally take care of you.
    https://www.supersprings.com/shop/ssr-611-40/
  12. Sep 26, 2019 at 4:34 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    Lol...That's my problem. I'm not sure either. I thought about installing a 1" block on the rear the day before I leave, and removing it after I get home. About a 30 minute job to put one of them on...
  13. Sep 26, 2019 at 4:38 PM
    hastingsrussell
    hastingsrussell Well-Known Member
    Russell
    Allen, TX.
    2016 Tacoma TRD Sport
    Pretty stock for now
    I just got my Roadmaster Active Suspension today and will install them this weekend. I didn't want to lift my truck and I work out of my truck with a topper and several hundred pounds of equipment in the bed. The road master is designed to handle the weight better and keep the truck closer to factory ride height.
  14. Sep 26, 2019 at 4:38 PM
    su.b.rat
    definitely don't do a block. if you are considering that, do the Sumos. it's the balance of cheap, easy, and an easy change if you want more. i have them and like them for when i haul, but I don't do heavy or trailers, so listen to these guys who run a similar weight setup.
  15. Sep 26, 2019 at 4:50 PM
    10SE TACO
    10SE TACO Active Member
    Dave
    Nashville, TN
    2018 TRD Sport Barcelona Red
    No mods. Yet...
  16. Sep 26, 2019 at 4:56 PM
    su.b.rat
  17. Sep 26, 2019 at 4:57 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Add air bags to the rear. You can adjust for your load or if you are towing, and lighten it back up when it's empty. You'll increase your load carrying ability but you won't have to deal with stiff rear suspension when it's empty.
  18. Sep 26, 2019 at 4:58 PM
    10SE TACO
    Dave
    Nashville, TN
    No mods. Yet...
    Oh! I’ve never seen them before. Guess I should have looked them up before I posted. ‍
    SteelerJim[OP] and -Paolo- like this.
  19. Sep 26, 2019 at 5:02 PM
    su.b.rat
    all good, he's just considering all the options. thanks for posting it.
  20. Sep 26, 2019 at 5:05 PM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    I would go leaf pack or AAL if you plan on doing a lift soon anyway. Especially if you plan on having the shell on all the time. I know lots of guys say they don’t get any sag from a shell, but I did bad. Might be a long bed thing.
