Rear suspension question
Discussion in '1st Gen. Tacomas (1995-2004)' started by sbacchus, Mar 19, 2025.
  1. Mar 19, 2025 at 12:20 PM
    sbacchus
    sbacchus [OP] New Member
    All,
    starting to feel some rear end vibrations on my 01 PreRunner double cab, was thinking about changing out the rear shocks and maybe the leafs. Problem is I'm not sure if it's currently stock or not. Can you tell from these pics?PXL_20250319_182337664.MP.jpg PXL_20250319_182516390.MP.jpg PXL_20250319_182400893.MP.jpg PXL_20250319_182412180.jpg
  2. Mar 19, 2025 at 12:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    Describe the vibrations and conditions they occur under.
    Miles on truck?
    Vibrations are much more likely to be tire related than suspension. One easy test is rotating tires To the front and see if the vibration follows
    sbacchus[OP] likes this.
  3. Mar 19, 2025 at 12:26 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    rear suspension looks stock. Vibrations can me caused by multiple things. I bit more information about your truck would be helpful.
  4. Mar 19, 2025 at 12:41 PM
    sbacchus
    Thanks for the responses. Truck has 226K. It feels kinda like the rear end is bouncing a lot, I figured with miles why not go ahead and refresh the rear suspension as I already did the front last year.
  5. Mar 19, 2025 at 12:43 PM
    02hilux
    Planet: EARTH
    Bad tires, wheel lost balance or bent, bad CSB, unbalanced DS, loose lug nut to DS mounting, or defective ujoints.
  6. Mar 19, 2025 at 12:47 PM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    White paint dot on leaf is original.
  7. Mar 19, 2025 at 12:58 PM
    Toyoda213
    Jimmy
    SoCal
    Then its time to do the rear suspension. I would also inspect u joints, carrier bearing and check the tires/wheels.
    sbacchus[QUOTED][OP] likes this.
  8. Mar 19, 2025 at 1:12 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Rear springs look flat, shocks will make it ride better for now. But the springs eventually need to be addressed.
  9. Mar 19, 2025 at 3:51 PM
    sbacchus
    visually I got the same impression, that the springs looked kinda flat.
