Rear suspension sag (passenger side)
Discussion in 'Suspension' started by geolink, Jun 26, 2009.
  1. Jun 26, 2009 at 8:30 AM
    geolink
    geolink [OP] Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    Before I go to my TSB Service Dealer, I would like to know if anyone else has (had) this condition.
    Truck = 09 double cab long bed TRD Sport with Canopy.
    Rear Suspension issue.
    Compared to the left (driver) side distance between bed frame and the axel:
    Before TSB rear 3 Springs sets were replaced the right rear sagged 5/8 inch between the bed frame and the axle.
    After the TSB rear 4 Springs sets were installed, the the right rear still sags 5/8 inch between the bed frame and the axle.
    I did not notice this condition until sometime after the canopy was mounted. I do not think the (evenly dispersed) canopy weight is relevant.
    Because the sag existed with the 3 spring sets and still exists with the 4 spring sets, this does not seem to be an issue with the springs. Any ideas? - faulty from the factory? How to correct?
    This sag is exaggerated to 1+ inch at center of right rear wheel fender (above hub).
    Want to get this resolved before any more lift alterations.
    Much thanks for any thoughts/input!
  2. Jun 26, 2009 at 1:27 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Weird, my truck is literally dead level.
  3. Jun 26, 2009 at 1:43 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    are you talking about the tacoma lean
  4. Jun 26, 2009 at 1:54 PM
    geolink
    SILVER STATE
    No, this is on the opposite side, the passenger side.
  5. Jun 26, 2009 at 2:04 PM
    geolink
    SILVER STATE
    Yes it is weird. I would think there are some side to side suspension level tolerance specs. The right rear sag is noticeable (1+ inch lower).
    Just wondering if anyone else may have experienced this?
  6. Jun 26, 2009 at 2:16 PM
    sincitytaco
    Las Vegas
    actually my passenger side rear is about 1/8 inch lower. and the front is dead level, but I had to adjust my coilovers accordingly to get it that way.
  7. Jun 26, 2009 at 2:30 PM
    geolink
    SILVER STATE
    Understand, However only alteration so far is the 3 Spring sets for the 4 Spring Sets. This 5/8 - 3/4" Right Rear Sag is most easily noticed when comparing the Bumpers to the Bump Stops.
    Unloaded bed (just the canopy):
    Right rear Bumper to Bump stop = 2 7/8"
    Left rear Bumper to Bump stop = 3 5/8"
    Even if it is the new TSB 4 Spring sets, should they be out that much???
  8. Jun 26, 2009 at 2:47 PM
    sincitytaco
    Las Vegas
    Thats weird, all tacomas normally lean to the other side. Has your truck been in a wreck with frame damage. Maybe the springs were installed on the wrong side. They do make left and right springs.
  9. Jun 26, 2009 at 3:08 PM
    geolink
    SILVER STATE
    No damage, this truck is 2 mos old and (my) 2800 miles.
    Good question about which side the new springs are installed on.
    I just confirmed the new TSB 4 Spring sets are the correct part numbers. They were installed by dealer yesterday:
    Part number RR RH 48210-04570 installed on Right side.
    Part number RR LH 48210-04210 installed on Left side.
  10. Jun 26, 2009 at 3:11 PM
    sincitytaco
    Las Vegas
    I see you live in "Silver State" if you are in las vegas go to skips spring service and have him either arch one side or de arch the other to make it level.
    I had this done a while ago and he took 3/4 inches out of one side to make the truck sit square.
  11. Jun 26, 2009 at 3:43 PM
    geolink
    SILVER STATE
    Thanks for the suggestion sincity.
    I see you did the 4 Spring TSB. Did you do the arching on these TSB Springs? I am trying to understand if my situation is rare.
    I am in Elko - Reno is an option. Would you recommend arching (de-arching) the TSB springs to level the truck before any other alterations?
    Thanks for your input / sharing your experience.
  12. Jun 26, 2009 at 4:04 PM
    sincitytaco
    Las Vegas
    I did have the TSB springs, but I took them off and put the 3 leaf ones back on again. I didin't like how much the TSB springs lifted me and I had to run too much preload on the coilovers to make the truck sit level. So I put the 3 leafers back on to lower the rear and make the truck ride softer. Like it now even though I still think the coilovers are a tad firm, but I may get them revalved in a year or so.
    No my truck has always sat dead level in the rear. When it was new the driver side front sat about 1/2 inch low, but I fixed that with coilovers now the front is dead level, but the driver side rear sits about 1/8 inch higher, when I have a full tank it is dead level on all 4 corners.
  13. Jun 26, 2009 at 4:31 PM
    geolink
    SILVER STATE
    Thanks sincity for clarifying.
    My situation must be unique.
    Both Spring Sets (stock 3 leaf and TSB 4 leaf) seem to behave the same.
    Right rear sag exists regardless of which springs are mounted. I did not address it with the dealer when the 3 Spring sets were on, thinking that the new 4 Spring Sets would correct it. They did not.
    From what I have learned, it seems that tweaking springs are a way to "adjust" the sag.
    I would rather address the real sag problem, which would be ????
    I appreciate everyones comments - please continue if any more ideas.
    Come Monday, looks like it is back to the dealer - they will not like to see me after they just installed the TSB 4 Spring Packs, but this (passenger side) sag on this new truck does not seem normal...
  14. Feb 22, 2010 at 9:12 AM
    Bobcat
    Bobcat Well-Known Member
    Montana
    So what was the cause?
  15. Feb 22, 2010 at 12:30 PM
    Bobcat
    Montana
    He has the sag on the passanger side. That is why he started the thread, cause it was opposite everyone else.
  16. Apr 30, 2012 at 10:47 PM
    ponokauai
    ponokauai Member
    pono
    kauai!
    2003 tacoma 4x4 revtek leveling kit 5% tint
    i have the same exact problem and still cant find out the problem... i was thinking maybe the previous owner of my truck installed the passenger side leafs on the driver side and the driver side on passenger??? anyone got any suggestions? maybe add a 1" spacer between my frame and bed of truck?? :p
  17. Jan 4, 2019 at 10:24 PM
    Firstgen619
    Firstgen619 Well-Known Member
    Jeremy
    San Diego
    1999 Tacoma 4x4
    Did anyone every figure this out I got the small problem
  18. Sep 27, 2021 at 10:55 AM
    11carbajal
    11carbajal Member
    I have the same problem. Rear passenger side sits almost 2" lower than the driver side! How can I fix the problem?
  19. Sep 29, 2021 at 9:00 PM
    233945
    233945 Well-Known Member
    Tom
    Boise, ID
    TAV Built 2018 TRD Access Cab / 2019 TRD DBSB / 79 LC BJ40
    What actually causes the lean to the drivers side? I've heard so many different reasons I'm not sure what is right.
  20. Sep 29, 2021 at 9:15 PM
    Bishop84
    Bishop84 Well-Known Member
    New springs. Not oem.
