Rear suspension to go with a 6" front?
Discussion in 'Suspension' started by JLamb11, Oct 21, 2010.
  1. Oct 21, 2010 at 1:58 PM
    JLamb11
    JLamb11 [OP] Well-Known Member
    Jared
    Orange County, CA
    08 PreRunner TRD Sport
    Regear, 6" Pro Comp Lift, Wicked Flow Exhaust, K&N Intake, T-Rex Billet Grill, Cobra CB, Wilson Flex 3', Radio Shack PA, Eyelids, Xenon HIDs, Tint, Kenwood GPS/DVD/Bluetooth...
    Hey guys, thanks in advance for the help. I have a Procomp 6" lift up front with Bilstein C-513's which I am ok with for now. As for the back end, it is still on leaf springs and just spacers I guess. I want to switch to a coil over set up. I was thinking OME's and Bilstein 5100's. Seems common enough. I do however, want to drop the back end a bit and prerunner it out a little more. So like a 4" lift in the rear and 6" in the front make sense? I am trying to figure all this out and appreciate the help.
    Thanks Jared
    (I will always have 35" tires, and I try and keep em wide)
    http://downsouthmotorsports.com/i-5...toyota-tacoma-pre-runner-4wd-rear-shocks.html
  2. Oct 21, 2010 at 2:01 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    get 885 coils with some ome shocks and run that in front, you will get like 8 inches in the front and keep the rear how it is
  3. Oct 21, 2010 at 2:05 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    get a custom leaf pack and ditch the block
  4. Oct 21, 2010 at 2:07 PM
    JLamb11
    Jared
    Orange County, CA
    Thanks for the feedback so far. I am not looking for anyone to do any research for me of course, but can you fellas be more specific? New to this. Bought this truck 3 weeks ago as is. First truck also
  5. Oct 21, 2010 at 2:11 PM
    PLC721
    Patrick
    Chandler, Az
    you have a 2" block with add-a-leaf springs, get a custom 6" pack from alcan for about 600 bucks shipped, that will solve your rear.
  6. Oct 21, 2010 at 2:12 PM
    JLamb11
    Jared
    Orange County, CA
    Thanks a lot. Any thoughts on dropping the back end a little?
  7. Oct 21, 2010 at 2:21 PM
    JLamb11
    Jared
    Orange County, CA
    Sorry, but in thinking about it, in what what will that benefit the trucks performance? Is it that it will have 2" more of travel in the rear because of the block being 'gone'?
  8. Oct 21, 2010 at 2:22 PM
    PLC721
    Patrick
    Chandler, Az
    blocks are well...shitty. you will have greater articulation with alcans(or any custom leaf pack) and a much smoother ride.
  9. Oct 21, 2010 at 2:24 PM
    JLamb11
    Jared
    Orange County, CA
    True that, true that. I appreciate your help in this thread and just have one other question, and that is the recommendations for dropping the back end a little?
  10. Oct 21, 2010 at 2:36 PM
    JLamb11
    Jared
    Orange County, CA
    Wait, can I just remove the 2" block. I also wanna remove the a arms
  11. Oct 21, 2010 at 3:17 PM
    PLC721
    Patrick
    Chandler, Az
    yeah but that'll be a big difference in height, esp if your lifting the front even higher. wait you want to remove your a-arms? they hold your spindle and you have to have them, thats a must.
  12. Oct 21, 2010 at 3:22 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    just get ome 885 and ditch the bock and get like a 1" block or aal
  13. Oct 21, 2010 at 3:22 PM
    JLamb11
    Jared
    Orange County, CA
    Got yuh, thanks a lot
  14. Oct 21, 2010 at 3:23 PM
    JLamb11
    Jared
    Orange County, CA
    Thanks for the input.
  15. Oct 21, 2010 at 3:24 PM
    kinkrider101
    santa barbara
    wheels and tires
    how much of a difference do you want? like same heigh in the front and lower rear..or same rear higher front...or higher front lower rear?
  16. Oct 21, 2010 at 3:25 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  17. Oct 21, 2010 at 3:27 PM
    PLC721
    Patrick
    Chandler, Az
    just so you know the procomp lift is a 6"/3.5" lift...so if you remove your block your going to have 6" up front and only 1.5" of lift in the rear.
  18. Oct 21, 2010 at 3:27 PM
    JLamb11
    Jared
    Orange County, CA
    I want to leave the front end alone for now and drop the back end a little. Not sure what each inch dropped looks like so ya. Maybe a 1" or 1.5" lower lift in the rear?
  19. Oct 21, 2010 at 3:28 PM
    JLamb11
    Jared
    Orange County, CA
    Nope did not know that. Thanks
  20. Oct 21, 2010 at 3:29 PM
    PLC721
    Patrick
    Chandler, Az
    remove your add-a-leaf will be your cheapest solution
