Rear Suspension TSB Revision
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJZ4, Feb 3, 2009.
  1. Feb 3, 2009 at 6:29 AM
    CJZ4
    CJZ4 [OP] Member
    Taylors, SC
    '06 Tacoma Ext. Cab 2.7L
    Int. Wipers
    FYI to all interested.
    I visited my local dearlership to get the TSB (T-SB-0305-08)installed on my Taco. I had a case number and a hardcopy of the TSB in hand.
    Sadly, I waited too long. They pulled up a revision dated January 12, 2009. I haven't seen it on TW.
    Rev. 1 stated that it now only applies to 4WD vehicles.
    I guess, during hard economic times Toyota is looking for all ways to cut costs.
    Bummer! I was really looking forward to having it done.:(
  2. Feb 3, 2009 at 6:34 AM
    confuzzed2
    confuzzed2 Member
    Colorado Springs, CO
    07 PreRunner
    Say it aint so, I was just about to try and get mine done. : (
  3. Feb 3, 2009 at 6:42 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Did they give you a copy of the new TSB that you could post?
  4. Feb 3, 2009 at 6:58 AM
    CJZ4
    CJZ4 [OP] Member
    Taylors, SC
    Int. Wipers
    No, they didn't. But I'll try to get one.
    I've tried to find the complete TSB on the web, but haven't as off yet.
    I'll keep trying.
  5. Feb 3, 2009 at 7:00 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    argue the fact that your prerunner has 4x4 suspension components
  6. Feb 3, 2009 at 7:18 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    Has any one priced out what the left pack costs? I find this to be a serious problem and if need be, I will pay for the upgrade myself.
  7. Feb 3, 2009 at 7:22 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I fail to see why the issue sohould be based on whether or not it is 4x4. The rear suspension, I believe, is identical and this is an issue of payload, not drivetrain.You should call corporate and argue your case. The payload listed for the stock suspension is false advertising.
  8. Feb 3, 2009 at 7:24 AM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    Luckly I already had mine done...but just curious...which dealership did you visit?
  9. Feb 3, 2009 at 7:28 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Last time I looked it was cost-prohibitive to buy the Toyota parts outright.
    Someone posted the prices in the other suspension-TSB thread.
    I would go for the the Dakar springs from OME (and probably the front setup from OME to do it right.)
    You would have a better product at a lower price.
    If Toyota doesn't do my 09, I'll do the above.
  10. Feb 3, 2009 at 7:40 AM
    CJZ4
    CJZ4 [OP] Member
    Taylors, SC
    Int. Wipers
    I used Toyota of Greer. They said that since the TSB Revision was specific about it being for 4WD vehicles, their hands were tied.
  11. Feb 3, 2009 at 7:52 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That's just retarded, the prerunner has 4wd suspension, just not the transfer case & front drive axles. Have them look at the inside of the front spindles & ask what that pressed in metal plug is that fills the area where the drive shaft would go through. Ask them to look at part numbers from prerunner & 4wd & hmmm, if the same how can they justify that shit? Mine has 48k when purchased so I'm basically fucked on that....
  12. Feb 3, 2009 at 8:00 AM
    ugotdubbz
    ugotdubbz Well-Known Member
    Chesterfield, Va
    06 DC PreRunner
    Rear spring TSB, OEM tube steps, in-channel wind deflector, OEM front seat covers,5100's up front set at 1.75"
    I had my prerunner done on Jan 28th and the parts were ordered on the 23rd with no issues at all. I think your dealer is not reading the TSB correctly. I did not have to argue for it or anything.
  13. Feb 3, 2009 at 8:03 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The one I saw said prerunner & 4wd on the top of it.............
  14. Feb 3, 2009 at 8:14 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007&#8206;
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    I just took mine in to the dealer two days ago and he already got approval to do it to mine. Parts are on order and they should be in by the end of the week they said... Try talking to another dealer.
  15. Feb 3, 2009 at 8:20 AM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Wow I am back at work tomorrow I will look for a revision to T-SB-0305-08 but I check daily for new info and keep an eye for stuff related to the Tacoma if there is something new I will post it as soon has I have it. CJZ4 I think they are pulling your chain and just don't want to do it for you try another dealer.
  16. Feb 3, 2009 at 8:31 AM
    ugotdubbz
    Chesterfield, Va
    06 DC PreRunner
  17. Feb 3, 2009 at 8:36 AM
    CJZ4
    CJZ4 [OP] Member
    Taylors, SC
    Int. Wipers
    If I had not seen the TSB myself, I would've thought the same thing. I don't trust them anymore than I trust an elected official!
    But alas, I saw it. I had pulled a copy of the TSB from TW and had it with me. But, his copy had a Rev.1 which mine didn't have.
    I don't know whether this vehicle will safely carry it's stated payload or not. But, given my close proximity to 36 months, I may be toast unless this falls under the 60K drivetrain warranty.
  18. Feb 3, 2009 at 8:53 AM
    CAdiveTaco
    CAdiveTaco Well-Known Member
    Nor Cal
    2009 Taco DC LB Pre Runner TRD Sport
    Bed Extender, Bed matt, G4 Fold-a-cover, debadged, locked spare, taigate hoe clamp mod, TW stick
    I just dropped off my truck last night at the Dublin Toy dealership along with a copy of the TSB. They are supposed to call me today and let me know if they will be able to cover this.
  19. Feb 3, 2009 at 8:57 AM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    So does the January 12th revision include 2009 models or are they still waiting for the 2010 models to come out before they do that?
  20. Feb 3, 2009 at 8:57 AM
    grivera
    Hanover, MD
    Look above your last post. Your dealer is obviously "twisting" the wording on Rev. 1 to avoid doing the TSB. It is clear in the parenthesis that the PreRunner IS covered. Call corporate and make a complaint. Provide names of folks at the service department and I bet they all you to have you bring it in and have it done.
