Rear Suspension
Discussion in 'Suspension' started by Silver06Taco, Oct 5, 2009.
  1. Oct 5, 2009 at 5:04 PM
    Silver06Taco
    Silver06Taco [OP] Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    I bought a used 2006 DC TRD Sport a little over a month ago. As far as I can tell the rear TSB has not been done. Any time I go over a speed bump or rough road it sounds like something in the bed has gone airborn and drops back in the bed. Or possibly it's bottoming out on something, I'm not sure.
    What is that noise??? :confused: It's driving me crazy. I didn't notice it on the test drive. Is that the TSB noise I keep reading about? I have pulled a trailer with 1.5 yards of gravel in it. It pulled fine and didn't sag the rear end with the loaded trailer. Could it be the shocks, which are stock? I can make the noise manually by lifting up on the bed and letting it go. Can the shocks be adjusted at all? The truck has 65k miles on it, so I wouldn't think the shocks have gone bad already. But who knows, I'm not all that mechanically inclined when it comes to vehicles.
    Any help would be awesome!
  2. Oct 5, 2009 at 5:10 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Could be the trailer hitch...
  3. Oct 5, 2009 at 6:17 PM
    Silver06Taco
    WA state
    I've checked that, it's tight
  4. Oct 6, 2009 at 3:29 PM
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Is the spare tire all the way up nice and snug or is it bouncing around?
    Also look for a loose muffler/exhaust system (some of the mounting is gone).
    I can't imagine much else unless you are hitting speed bumps hard and a rough road to you might be off road to me.
    I hope that helps and I'd like to know what you find out.
    -Joe
  5. Oct 7, 2009 at 12:02 PM
    Silver06Taco
    WA state
    I've checked the spare and it's good.
    The muffler/exhaust is a good idea. I'll have to check this weekend, when I have time.
    I can roll over speed bumps and hear it at times.
    I was thinking maybe the bed is dropping down on the bump stops, but not sure. My brother in law was thinking maybe the rubber grommets on either end of the shock have gone bad. He was thinking this as it mainly seems like it's coming from the drivers side. But I haven't had time to get it into a shop.
  6. Oct 7, 2009 at 12:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like the shock is topping out. You need longer shocks.
  7. Oct 7, 2009 at 12:05 PM
    Silver06Taco
    WA state
    That could be an option. Is there a way to tell before I go buy new shocks?
  8. Oct 7, 2009 at 12:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Does it sound like a "THUMP" ??
  9. Oct 7, 2009 at 12:06 PM
    Silver06Taco
    WA state
    I was thinking...if I am hitting the bump stops in the rear, how do I fix that? Is that with new shocks, leaf springs, etc.?
  10. Oct 7, 2009 at 12:06 PM
    Silver06Taco
    WA state
    Yep, exactly. It sounds like I have something laying in the bed and when I go over something, it goes airborn and then lands in the bed...something heavy
  11. Oct 7, 2009 at 12:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats how you tell. What shocks do you have now? Stock?
  12. Oct 7, 2009 at 12:11 PM
    Silver06Taco
    WA state
    Yep, their stock...TRD Sport
  13. Oct 7, 2009 at 12:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Get the 5100's, and you can thank me after they are installed. :)
  14. Oct 7, 2009 at 12:17 PM
    Silver06Taco
    WA state
    I've read a lot about those and they were the ones I'd probably get. But I wanted to make sure that was the problem, first.
  15. Oct 7, 2009 at 12:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats the problem. I was able to re create the problem on my truck with OEM shocks. As soon as I threw the 5100's back on, it went away.
  16. Oct 8, 2009 at 2:46 PM
    JoeSchmuck
    Joe
    Virginia
    Just so I'm clear... When the shocks top out, they are fully extended and the suddend travel stop makes the noise. I can see that if the truck was lifted or the shocks have failed, or if the rear of the truck was lightened up.
    I guess you could test for it by putting a few hundered pounds of something in the rear of the bed and drive it. I like going to Lowes so that's easy for me. That would act as a dampener and might keep the shock from toping out, but if it's a bottoming out problem, you would see it more. If it's a loose bed you should be able to move it by hand up and down in one of the four corners. The beds are not that heavy to prevent you from finding a problem of that magnatude.
    I doubt it's the leaf springs and I agree which chris, the shocks are probably your problem. If they top out or allow the bed to hit the bump stops, it's likely the shocks.
    I'd still like to know what solves your issue.
    Joe
  17. Oct 13, 2009 at 3:57 PM
    Silver06Taco
    WA state
    Problem solved. I had new shocks put on today. I ended up going with the Monroe Reflex. The reason I went with those are the guy I've gone to for years gave them to me dirt cheap ($35 a piece) and said they were a good smooth riding shock. I have to agree!
  18. Oct 13, 2009 at 5:00 PM
    JoeSchmuck
    Joe
    Virginia
    Great to hear you got the truck working good. Looks like Chris nailed it.
    Hope you enjoy your ride.
    Joe
  19. Sep 8, 2011 at 5:01 PM
    FLyhighdp
    FLyhighdp Member
    flyhighdp@gmail.com
    flyhighdp@gmail.com
    is the 5100 the factory shock that came with the truck? I'm rockin a '05 4dr. sport 4wd.
  20. Sep 8, 2011 at 5:21 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    when adding new rear shocks do you need to realign?
