Rear sway bar for 2nd gen base model?
Discussion in 'Suspension' started by yota13, Feb 6, 2013.
  1. Feb 6, 2013 at 9:49 PM
    yota13
    yota13 [OP] Member
    I understand the x-runner front springs and shocks are easy to obtain and swap right over.
    What about the x-brace? is it a bolt on affair?
    and is there an OEM option for a rear sway bar on the base model tacoma?
    Does anyone have a picture of a base model with x runner suspension?
    Basically I want my truck to handle a lot better than it does right now. Thanks a bunch!
  2. Apr 2, 2013 at 1:44 PM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    I hear that some of the people who have made double cab x runners just swapped the body onto a whole different frame. As for sway bars I think the x runner has them as I read the aftermarket units bolt into the existing holes. People seem to think the rear sway bars help a ton. Aftermarket shocks with or without springs can help a ton as well but I see no reason to lower it. My truck will slide before it rolls very much but I have a dclb sport. I have ridden in a budy of mines lifted f 150 which handled better than stock just because he used good components. Hope this is helpful.
  3. Apr 2, 2013 at 1:49 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Don't confuse the x-brace with a rear sway bar, they are not the same. The x-brace stiffens the rear section of the frame, a rear sway bar would help counter body roll in corners. Hellwig makes a rear sway bar for the 6-lug Tacoma although I'm not sure if it's a universal fit for 5-luggers also. I believe Famous Fabrications was making something similar to the x-brace for 6-lug Tacomas as well. It bolts to the rear hanger bolt and the cross brace in front of the rear tire.
  4. Apr 3, 2013 at 4:40 PM
    urban
    Illinois/Michigan
    Me? I know the difference between the two, my appologies if i didn't write it clearly... I only go to the former General Motors Institute of Technnology....but whateva....
  5. Apr 4, 2013 at 5:21 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    He was just trying to clarify. No need to be an ass. :rolleyes:
  6. Jun 19, 2013 at 4:53 PM
    electrcguy
    electrcguy Active Member
    Dan
    Baltimore
    Red 4x4 Taco
    all stock!
