Rear sway bar parts question
Discussion in 'Street Trucks' started by jmarquez808, Jan 17, 2013.
  1. Jan 17, 2013 at 9:32 AM
    jmarquez808
    jmarquez808 [OP] Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
  2. Jan 28, 2013 at 9:56 AM
    carlos82
    carlos82 Member
    JUAN
    IRVING
    1996 4RUNNER SR5
    i'm a toyota parts guy and I would Not recommended. The new one will only cost you 58 bucks anyway. That money you are tryinng to save might cost you hundreds of dollars later.
  3. Jan 28, 2013 at 5:38 PM
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Hard to tell which one you should buy since we don't know what the difference is between 'standard' and 'professional'. Sometimes, 'professional' simply means more money for little or no gain to the consumer. The one you linked to looks OK to me... it's just going to get all rusty and buggered-up, so who cares what it looks like.
    I had an end link on my front swaybard snap because I had apparently tightened it down too much (lesson learned). However, because it's just a sway bar, I don't think the end link failing is a life threatening issue... just more annoying.
  4. Jan 29, 2013 at 2:30 PM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    thanks guys i scored with a slightly used full setup for all the hardware i need so thankyou for the input!!
