Rear Sway Bar?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RickW, Sep 7, 2024.
  1. Sep 7, 2024 at 9:57 PM
    RickW
    RickW [OP] Well-Known Member
    Rick
    Stockton, Ca
    07 Tacoma daily driven
    When I go skiing I take a windy mountain rd.
    Better cornering wouldn't hurt.
    Any experience out there?
    TIA
    Rick
  2. Sep 8, 2024 at 5:57 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    SOS performance makes a kit where it utilizes the rear sway bar from a Tacoma XRunner.
  3. Sep 8, 2024 at 9:48 AM
    TacoTuesday1
    FL
    Improving my suspension improved my cornering. And alignment.
    deleted sway bar.
    -more pros
    -no more cons
    -less things to deal with
    I don’t know about understeer. The engine is not that far forward nor frontal power distribution like under steering cars tend to do.
    if anything a stock TRD Sport without a rear bar tends toward oversteer. Depends on the configuration of the truck.
  4. Sep 8, 2024 at 10:07 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I went from stock front coil springs to 600 lbs. Previously the truck wallowed in the turns, no longer. You can also try carrying more weight in the bed.
  5. Sep 8, 2024 at 10:12 AM
    Bishop84
    Bishop84 Well-Known Member
    It's a big improvement for some, I know a few tundra owners that used to put it on right away.
    Stiffer springs help, but a rear sway bar literally prevents roll in corners by using the counter torsion to keep the bed from rolling.
